RV.Net Open Roads Forum: Tech Issues: "Fuel Efficient" charging pattern?
 > "Fuel Efficient" charging pattern?
racefan1965
Redding, Ca.
Posted: 06/23/08 11:05pm Link  |  Quote  |  Print  |  Notify Moderator
Dixonmatco wrote:
Absolutely Wayne.. And the OP has a 3500W constant speed generator to use for battery charging. This is much larger than necessary to do the job and as a result, uses much more fuel. According to the published figures, the Champion 3500W uses over 1 gal per hour at 50% load and the Honda gets 15 hours on 1.1 gal at 1/4 load.
Yes, my Honda is only running at about 1/4 load when battery charging, even at bulk charge rates with my PD9260. The Champ 3500 would be at less than 1/2 load, but I was unable to find any other consumption specs for it. Greengreen says less than 1 gal per hour, but still that does not compare to less than 1/10 gal per hour.
One thing brought out on this string was the importance of adding solar to the system if you are a long term boondocker, and the need to fully charge the batteries at regular intervals to avoid sulfating.. Personally I keep my TT plugged in when it is stored, so this is not a problem.
Great information here though...
The published figures your stating for the champion are wrong. My champion uses less than 1/2 gallon per hour at full load. Others report the same. Read the 3000watt genset thread for clarification.
Using a genset just to idle and charge batteries is a waste of gas and machine IMO. If that's all you want to do is recharge bateries go with solar and inverters. That would be a really smart decision.
Rick, Shirley, Lacy, Misty and 2 dogs(Shasta & Baylee)
1999 Dodge 2500 Quad Cab 4X4
1984 Alpenlite24 5er
1988 Coleman pup
2006 Champion C46540 RV plug ready genset
klenger
Tucson AZ
Posted: 06/24/08 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Consider getting solar to top off the batteries. The generator / solar combo works great. See my sig for details.
2008 Tiffin Allegro 32BA FRED Class A Motor Home
2008 Honda CRV, Blue Ox, SMI DUO Stay-in-Play Brake
liborko
Surrey, B.C.
Posted: 06/24/08 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
I agree 100%. I run generator every morning until charging current drops to about 10A. Then solar takes over and in about 2-3 hours depending on the amount of sunlight batteries are fully charged. Two U2200 and Prosine 2.0, two Sharp 123W solar panels with Blue sky 3024i controller.
