Since it's "Just out of the box" I'm guessing it's just the first time it's hotted up.. But I would suggest you try a couple more times.. If it continues to "Smell hot" do as you have done and find someone who's better at "Smell Detection" (IE: a honda service tech) to come over for a "Cool one" and a sniff.
Nothin adds excitment like something that is none of your business John is Near Kenwood TS-2000 housed in a 2005 Damon Intruder 377
I have the Honda 3000 generator, Mine had a new burning smell when first fired up. Mine starts my AC just fine. If the Honda is overloaded for some reason, It has a auto-shut down to keep from burning up.
Run your Geny again, keep an eye on it as you let it warm up and run thru the cycle. The burning new smell should go away
But, keep an eye on it just in case something is wrong, It wont start woty-out oilm and will even shut off automatically if it runs low on Oil
i have had to run 15,000 btu a/c off my 2000 honda and it worked. straining (slightly)when comp kicked in high but handled it. wouldn't try to run micro but we were cool. (CG power went out). coleman a/c.
06 F250 6.0 TD,SC,SB,4x4,Towboss,3.73 rear.Firestone air bags,285/70 R17 3795lb tires,18000 slider; 04 38' Jayo Designer "Legacy" 5er; all I need now is satilite TV and hit the lottery; NAVY,"WE'LL NEVER FORGET,land of the free because of the brave"
TandA-n-Mac wrote: i have had to run 15,000 btu a/c off my 2000 honda and it worked. straining (slightly)when comp kicked in high but handled it. wouldn't try to run micro but we were cool. (CG power went out). coleman a/c.
