RV.Net Open Roads Forum: Tech Issues: Charger/converter question
 > Charger/converter question
lzcamper
Thousand Oaks, CA
Posted: 06/19/08 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Does a charger/converter charge both the starter battery and the house batteries or just the house batteries?
Rick
big dave
Soldotna, Alaska, USA
Posted: 06/19/08 09:42am Link  |  Quote  |  Print  |  Notify Moderator
Generally speaking, no.
Dave & Rose C
90 Safari Ivory 34' DP
04 Saturn VUE V6
JFG
TN
Posted: 06/19/08 09:43am Link  |  Quote  |  Print  |  Notify Moderator
House
Fred
fncampn
Gardnerville, NV
Posted: 06/19/08 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Unless your charger wiring has been modified to charge both, the charger in the converter charges the house batteries and the engine alternator charges the starter battery(s). They are two separate charging systems but can be wired to have either system charge either set of batteries.
Cold Weather Camping Mods
A Bunch of Ways to Mod Your RV
'08 Ford F150KR Screw 5.4L LB Auto 3.73LS 4x4
'07 Ford F350 XLT CC LB PSD Auto 3.73 4x4 - SOLD
'08 Thor Summit 27RBS TT - 9000 GVWR, 7500 loaded, 875 TW
'06 Kipor 3500Ti Generator
Caseydon
Simonton, Texas
Posted: 06/19/08 09:50am Link  |  Quote  |  Print  |  Notify Moderator
As you've been told, just the house. A convenient way to make it charge both is to install a Trik-L-Start charger. Simple to install, no attention required. In most motor homes, there is a relay that connects the coach and chassis 12 volt systems when the ignition is on. The Trik-L-Start connects across that relay.
Casey
smkettner
Posted: 06/19/08 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Plug into utility power and the next morning check the voltage on both batteries. If they are both 13.2 to 14.4 volts they are being charged. 12.8 or less and they are not being charged. I also recommend Trik-L-Start if needed.
Hurricaner
Hurricane Utah
Posted: 06/19/08 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Bad answers on this thread. Many motorhomes such as mine are setup to charge both. Intellitec provides a device to many manufactures that is known as a BIRD. It charges both batteries whenever the voltage is over 13.2 and stops when it drops to 12.8. So the correct answer to your question is, some do and some don't.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
Wherever I happen to park
Posted: 06/19/08 11:19am Link  |  Quote  |  Print  |  Notify Moderator
House always.. Chassis sometimes
Mine, for example, does both... I think "Both" is the "Minority" however
If yours does not then there are add-on devices that will fix it so it does
The Trick-L-Start is one such
ejforwood
Littleton (Denver) Colorado
Posted: 06/19/08 11:43am Link  |  Quote  |  Print  |  Notify Moderator
If you have a Bounder, the answer is: Yes it charges both.
If you have a SOB, I don't know.
Jerry, Dottie & Chan, "the little furry one"
98 Bounder 34V, 99 F-53 Ford V10 chassis
06 Saturn VUE 4I
lzcamper
Thousand Oaks, CA
Posted: 06/19/08 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the information. Answers to one question lead to many more questions.
I had planned to install a charger/converter in my DIY van in a couple of weeks, but I'm wondering if I could just use a charger instead of a charger/converter. All of the appliances in my van run on DC, so what's the advantage of using charger/converter instead of a charger? When plugged in to shore power with a charger/converter, it seems like one could save the propane that the refrigerator uses, but what else? Does a charger charge batteries faster?
Rick
