RV.Net Open Roads Forum: Class C Motorhomes: GVWR On class C
 > GVWR On class C
PineKap
So Cal.
Posted: 06/19/08 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Hello all.
I have friend that is looking at Class C. The GVWR is 14,500 with a dry curb wieght of approx 12,200. This only gives him 2300 pounds to work with. Is this the norm on class C motor homes or should he be looking for something a bit better?
Thanks for the replies in advance.
Kevin
Polishnurse
Schodack, NY
Posted: 06/19/08 11:42am Link  |  Quote  |  Print  |  Notify Moderator
Could very well be, then add the LPG, water, Gas, underware, the eats, he should be pretty close.
Make And Model, Year. Then maybe some others can help. Bill
jauguston
Bellingham, WA
Posted: 06/19/08 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Pretty common. Some are over empty.
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
TomW2
Southwest Washington State USA
Posted: 06/19/08 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
Carry very little water and fewer than the rated # of people and you can stretch things somewhat. Even so, I've got space I can't use because of the weight limit. Heck, I'd be happy just to have the extra 450 #s that the newer chasis have.
PineKap
So Cal.
Posted: 06/19/08 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Class A and have about 3400lbs capacity. But i have not done any research on the Class C. So from what your saying is that 2200lbs is the norm for a class C's storage capacity?
Kevin
Thanks.
ABBACUS
Lakehills, TX
Posted: 06/20/08 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
I full-time in a 08 Jayco Melbourne I have weight it atleast 10 times. Load with everything, wife, dog, Hydro Jacks, Air bags, food and to many clothes it weight 14200 with 30 gals gas 20 gals of water. I had some warranty work this last week and I took everything out except dry food goods and cooking stuff. It weight 13200.
I would not worry to much about only having 2000 listed, load it up and get it weight. I normal travel with only 10 gals of water. I hope this helps.
Bobby K5ypp
we-berving.com
Gene in NE
Omaha
Posted: 06/20/08 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
PineKap - To answer your question, I would say you would be much better than most Class C's with 2,300 lbs to work with. Many Class C's are 29 or 31 foot units with multiple slides and do not have nearly that capacity.
If you are looking for more capacity, think shorter.
2002 Trail-Lite Model 211-S w/5.7 Chevy
Gene
PineKap
So Cal.
Posted: 06/20/08 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
I am not looking to buy. I am asking for a friend of mine who is looking to buy a Class C. We are just wondering if 2200lbs is the norm Storage capacity or should he he be looking for a Class C that has more capacity. BTW he is looking in the 30' Range.
Thanks
Kevin
MichaeleH
Fort Lauderdale,FL
Posted: 06/21/08 01:20am Link  |  Quote  |  Print  |  Notify Moderator
30' with no slides maybe, look for shorter if you have that much to carry. I don't hear many folks bragging about how much weight they carry You would have to check each of the brands out I don't know of any
melmar
Burleson, Tx
Posted: 06/21/08 05:20am Link  |  Quote  |  Print  |  Notify Moderator
My 31' Minnie weighs 13220 fully loaded with fuel, lpg, 1/2 tank water, 2 bikes, fishing gear etc all supplies for a week, 2 schnauzers, DW and myself. The MH has one slide and HWH levelers, so I don't see the problem preceived about a MH of this size having no carrying capacity. There's nothing else I would want to take and I'm still 1200 lbs under capacity.
2004 Minnie 31C
2007 Honda CR-V Toad
2005 Nissan 350Z Toy
2 Mini Schnauzers, Ernie and Misty
 > GVWR On class C
