Grillmeister
Iconoclast
Hi Gang,
I just made reservations at a local campground and the only site available had a special note "15 amp service only!".
I have run my RV air at home on a receptacle with a 20 amp circuit breaker many times and I can hold about 110 volts. I know a lot of factors at the campground are involved as to whether it will work or not but I am just wondering if everything was perfect, would a 15 amp circuit breaker carry the load from an A/C drawing 13.5 to 14 amps. I am thinking it might, but still might pop the breaker on startup, or might bring the volt reading down below an acceptable level. I have a month before the reservation so I have time.
Any thoughts? Thanks, Gary
Show me the GRILL and STAND BACK!!!!
hershey
Albuquerque,(fulltime) NM, USA
Probably not unless you can completely eleminate any other phantom or non-phantom draws.
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
TandA-n-Mac
new jersey
it all depends on campground electric quality. 15 amps is really pushing it. let me know if it works. and bring a geny just incase.
06 F250 6.0 TD,SC,SB,4x4,Towboss,3.73 rear.Firestone air bags,285/70 R17 3795lb tires,18000 slider; 04 38' Jayo Designer "Legacy" 5er; all I need now is satilite TV and hit the lottery; NAVY,"WE'LL NEVER FORGET,land of the free because of the brave"
Tarheel Traveler
Waco, Tx
When I originally wired my rv electrical post in the backyard, I put in a 15 Amp breaker. It did well until we turned the A/C on. It would trip the breaker all the time. So I went to a 20 Amp breaker no more tripping. So, I think you will have problems.
Tarheel Traveler
tvman44
Southwest Louisiana
Probably but you can not have anything else on, not even the converter.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
rv2go
Somewhere between Knoxville, TN and the coast.
I don't believe I would stake my comfort on the average 15amp CG service.
Winnebago Journey
TN Lic. RV 2 GO
1995 2dr. Hard Top Geo Tracker
www.rv2go.us
I'm here #4335
Travel Photos
trnfla
Tampa
I believe the campground would not be to happy with you if you tried.
Have a great time camping,
Terry
Please say a Prayer for my 12 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
John & Angela
Full Timers in Canada, USA and Mexico
More than likely you won't have a problem if you shut everything else off, make sure fridge is on propane, turn off the converter etc. We have done it a few times before without incident. Make sure you have a solid 110 volts from the source. Not sure why a campground would care unless the breaker blows and needs to be reset a lot.
Come visit us at our website and share in our great fulltime RV Adventure.
2003 Fleetwood Revolution 40C
Retired Canadian Air Force Technicians
Vernon,B.C,Canada.
jdkd123
Northeast
Even if the 15 amp breaker doesn't trip, like John & Angela, I'd be concerned about low voltage.
JDKD123
2005 Coachmen CONCORD
GO SOX!
smkettner
As long as everyone is not on the same feed running the air the voltage might be OK. You may need to let the converter run for a while to get the battery at 100% before you turn on the air. And you could just run on battery power so only the air was pulling from the 15 amp connector. Definately bring your volt meter.
