RV.Net Open Roads Forum: Full-time RVing: Wear and tear on your TT
Search only in Full-time RVing
Open Roads Forum  >  Full-time RVing
 > Wear and tear on your TT
GoneCamping
Chesapeake, Virginia
Posted: 06/24/08 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
Some makes are better suited to full timing than others. My TC was mentioned in the owners manual that it should NOT be used for FT, but I used it for 3 years and it have had no issues with appliances and devices. The only problem encountered after 3 years was soft spots in the floor, and that had to do with the aluminum-foam core-aluminum sandwich composite floor it has.
My Thomas Bus conversion on the other hand, has been built to my standards, and everything I did was intended for full time use. It still needs more insulation under the floors, but I've got all summer to get that job done!!
*Cliff*
Chaos reigns within. Reflect, repent, and reboot.
Order shall return.
2004 Trail Cruiser XP C-23B
1994 Jeep Grand Cherokee
1989 Thomas Diesel Pusher (Cat 3208/Freightliner)
saoesch
Fremont, MI USA
Posted: 06/25/08 10:22am Link  |  Quote  |  Print  |  Notify Moderator
We have an Open Road by Pilgirm and have been living in it for 6 months at a time for the last 3 years (this is our fourth) and have only had to replace the pop-off valve on the water heater. We think this was only due to the very hard water at the one park that we stayed at for 3 years.
saoesch
2003 Chevy HD2500 Crewcab/D-max/Allison/Bullydog Chip
2005 361-RKDS-5 Open Road by Pilgrim International
