RV.Net Open Roads Forum: Class A Motorhomes: Slide won't move
 > Slide won't move
turtle2468
MD
Posted: 06/20/08 11:13am Link  |  Quote  |  Print  |  Notify Moderator
I have a n 06 Damon Dabreak. When I push the button nothing happens. If I start the motor and shut it down I can then push the button and it works fine. What do I do if it gets stuck out. One is a cable slide? Anyone know whats going on? The battery level says that it is fully charged.
FrankReno
Reno, NV
Posted: 06/20/08 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Our coach, the engine must be running to move the slides.
Frank & Marion
2004 Southwind 36B
Workhorse W22
Little Green Jeep Toad
Driver Jake The Wonder Dog
Copilot Chip the Pup
sootslayer
Central Pennsylvania
Posted: 06/20/08 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have the operating instructions? They can certainly be a lot of help, just as this list is. But sometimes helps those on the list if you have a little more info. Most have instruction on how to get them back in if a motor fails and such...
Hank
turtle2468
MD
Posted: 06/20/08 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
Sootslayer, I do have them for the other slide, but not for the cable one. That's why I'm wondering.
chiefcramer
USA Somewhere
Posted: 06/20/08 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
A battery can show fully charged and not perform under a load.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2003 Odyssey
Two cats - Kitty & Casey (18 & 15 years old)
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what's left.
New rig - new Visited States Map
Brodie3Az
Arizona
Posted: 06/20/08 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
turtle2468, have you used the DamonRV website to submit a question?
turtle2468
MD
Posted: 06/23/08 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Good idea Brodie3AZ. It probably was the battery because after we drove it for about 2 hours it started working just fine. Thanks for all your replies. I still will go to the Damon RV website and ask just in case.
 > Slide won't move
