turtle2468
MD
I have a n 06 Damon Dabreak. When I push the button nothing happens. If I start the motor and shut it down I can then push the button and it works fine. What do I do if it gets stuck out. One is a cable slide? Anyone know whats going on? The battery level says that it is fully charged.
FrankReno
Reno, NV
Our coach, the engine must be running to move the slides.
Frank & Marion
2004 Southwind 36B
Workhorse W22
Little Green Jeep Toad
Driver Jake The Wonder Dog
Copilot Chip the Pup
sootslayer
Central Pennsylvania
Do you have the operating instructions? They can certainly be a lot of help, just as this list is. But sometimes helps those on the list if you have a little more info. Most have instruction on how to get them back in if a motor fails and such...
Hank
turtle2468
MD
Sootslayer, I do have them for the other slide, but not for the cable one. That's why I'm wondering.
chiefcramer
USA Somewhere
A battery can show fully charged and not perform under a load.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2003 Odyssey
Two cats - Kitty & Casey (18 & 15 years old)
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what's left.
New rig - new Visited States Map
Brodie3Az
Arizona
turtle2468, have you used the DamonRV website to submit a question?
turtle2468
MD
Good idea Brodie3AZ. It probably was the battery because after we drove it for about 2 hours it started working just fine. Thanks for all your replies. I still will go to the Damon RV website and ask just in case.
