ericosmith
Michigan
Right now I have one digital and one analog tv in the fiver. I always aim the antenna using the analog tv because I can usually find the stations even if the antenna is pointed in the wrong direction. Then I can rotate the antenna to fine tune the ones I want to watch and they'll be fine on the digital tv.
With digital, how do you know which way to point the antenna when you have no idea where the towers are? Point it the wrong way and you don't just get a faint signal, you get no signal.
wtravlr1
Palm Harbor, Flordia, and Geneva-on-the-lake, Ohio
slowly very slowly, in some way digital is better, but generally it a picturer/no picture. When tuned in, its good, but does not have the fringe pickup that analog does. Digital will pick up on a smaller fringe and pixelate. BTW the bat wing antenna is just fine.
2007 Forest River Sierra 31fkd (37') dual slides
chevy suburban 2003 2500-8.1 L.4.10's
prodogy/reese dual cam
rollgard springs
Fulltiming it since 2004. My only home.
My Homepage and Rv pics press here
KeninAZ
SE AZ
The tower locations will not change, just the equipment at the station they broadcast with.
John&Cathy
Climax, NY
The digital tower location can be in a different location from the analog one. Here in the Albany, NY area, digital 13 is about 15 miles from the analog 13 site.
Most of the digital here is now on one tower, aim the antenna once - everything comes in fine.
John
MGO BLUE
CAPE CORAL FL
I've been tuning the antenna with the analog channel and then switching to digital........When I reversed that the digital came in but analog was way off................
JesLookin
Appleton,WI
When tuning with the conversion box, it has a beeper that beeps faster when the signal gets better. Don't know if digital tv tuners have beepers.
2005 Sierra 285 BH
2003 Dodge 2500 Diesel, quad cab, short bed
mooreadventures
North Carolina
The box I got form WallWorld has an option under the menus for 'Antenna', when selected it shows a signal strength bar across the picture. I just rotate around until I get a good signal.
Mark & Tammy
'01 Excursion Limited, 4x4, V10, RoadMaster Active Suspension
'01 Prowler 31G
Equal-i-zer Hitch - Prodigy Brake Controller
John3872
Iowa
My HDTV's have signal strength bars. I'm not sure if all do, but this is how I tune mine.
2001 GMC 2500 6.0L
2006 Rockwood 8281SS
Reese 16K Fifth Wheel Slider
DrawTite Brake Controller
Norm K.
Destin, FL or on the road!
This will tell you where the antennas are located. Digital is pretty important to be pointing in the correct direction.
http://www.w9wi.com/tvdb/tvdbinst.htm
There is a www page that allows you to input your location and then it tells you what compass heading to point the antenna but i can't find it now.
'03 Silverado 2500HD Dmax/Allison XCab LB 4wd
'04 Montana 3400RL
flyfishing48
Cheboygan,MI
As john3872 mentioned, most digital TV's have a signal strength readout. Check your manual or poke around with the menu to find it.
Tom & Glo:
Hobbs (Golden Retriver)
Chevy 2500 Ext Cab Duramax
Sundance 2900 MK
