RV.Net Open Roads Forum: Travel Trailers: Anode Rod
 > Anode Rod
mjsabina
Palmerton,Pa
Posted: 06/20/08 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
When should I replace the Anode Rod? There is 8 3/8 inches rod inside of the hot water heater. About 1 inch is completely gone closest to the threaded side. Does it need to be replaced now or wait until it is almost completely gone? It is about 2 1/2 years old.
Thanks Mike
mjsabina
Palmerton,Pa
Posted: 06/20/08 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
USAFBILL
Alabama
Posted: 06/20/08 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
I replace mine yearly but if you still have some element left then your scheduale might be different.
Polishnurse
Schodack, NY
Posted: 06/20/08 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
A lot of people do it every year. It's some what cheaper then changing the hot water heater. It seems the winters can be rough on them, serious once they have been in the water for a session, then subject to air, it tends to make them turn to powder. Change it and be safe. Bill
Chuck&Gail
In the Colorado Mountains
Posted: 06/20/08 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
I did mine every spring.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
Fulltimers
Anywhere, USA
Posted: 06/20/08 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
If I remember right, Suburban recommends replacing when 75% is gone.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2001 Saturn SC2 (Mr. Toad
Photos
Scott_C
NJ
Posted: 06/20/08 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
If you've lost a majority right near the threads, it should be replaced as soon as possible. You'll find that anode rods are often spent unevenly.
2008 Shamrock 21SS
Adam-12
Northern CA
Posted: 06/20/08 10:57pm Link  |  Quote  |  Print  |  Notify Moderator
EXACTLY!
You need to make sure that you replace the rod when 75% is already gone, and/or if the threads start to show ANY little bit of corrosion. If the threads on the anode rod start to corrode, that means the threads on the tank are begining to corrode. If the tank threads corrode, you're screwed.
You can't replace the tank threads. The entire water tank must be replaced unfortunately.
When in doubt, replace your anode rod. They're cheap.
2008 Silverado 2500HD Duramax/Allison DIESEL/4x4/CC/Z71
2008 33ft. TT/BH-Super Slider
Parallel Honda EU2000i's
Yaesu 857d
Dipoles/random wire/tuners
Fishing equip.
Quads
Life member: NRA
ALCOHOL
TOBACCO
FIREARMS!
hpage3
Seabrook,New Hampshire USA
Posted: 06/21/08 04:49am Link  |  Quote  |  Print  |  Notify Moderator
I change mine every year usually at the end of the season,after I back flush the tank by removing the anode rod and inserting a hose inside the tank to get all the junk out. I use a water tank fill attachment on the hose as it will fit inside the anode rod opening. After letting it drain I wrap the threads with plumbers tape and screw the new one in and I'm all set for next season.
Howard Page
Seabrook,NH
07 Rockwood 8314SS travel trailer
08 Dodge Ram 2500 Heavy Duty 5.7L Hemi v8 quadcab
Tekonsha Prodigy Brake Controller
mjsabina
Palmerton,Pa
Posted: 06/21/08 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for all of your opinions.
Happy and safe camping to everyone.
Mike
 > Anode Rod
