RV.Net Open Roads Forum: Toy Haulers: The results of WW and Rage'n consolodation
Search only in Toy Haulers
 > The results of WW and Rage'n consolodation
2BlueHeelers
Roseville, CA
Posted: 06/20/08 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
Contrary to what you may have read in other posts (mine included) the demise of Rage’n Inc as an independent company may not be such a bad thing, at least not for WW.
WW restructuring (layoffs and plant closures) will give WW models a leg up especially in the strength and appearance of the WW wide-body line. They have replaced all wide-body frames with Rage’n frame design including the Z-Rail sidewall support structure. It’s been well documented that WW frames were $%@#, this was the remedy. Along with that, WW has adopted the Rage’n vacuum bonded, aluminum framed fiberglass walls that gave Rage’n that distinctive mirror finish.
The wide-body trailers and WW Motor Homes will roll of the line at the former Fleetwood plant. All ultra-lites (WW and Rage’n) will be produced at the Rage’n plant in Riverside.
So the end result is that WW gets a leg up in strength and appearance and Rage’n is still alive as a sister line and will continue to be marketed as a Rage’n.
Rage'n FA30-5
Chevy D/A
KFX700
Scrambler
jadoca
ca
Posted: 06/20/08 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Having owned both an 04 WW and 04 Rage'n I will say the Rage'n constuction was far superior in every respect. If the Rage'n construction did not change (as they say) after WW aquired them, the same could be said today.
Regards,
carringb
Corvallis, OR
Posted: 06/20/08 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
I would agree that the WW frames aren't strong enough. 6" frame rails on a 40'+ trailer? Needless to say, I managed to managed to break it.
But... if they now have stronger frames, and they can have a decent GVWR (something at least close to the axles ratings)... I might have to get me another. Until I read this, I was planning on doing a conversion of a larger race car trailer or stacker trailer.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, 230,000+ miles
Had: Weekend Warrior 41' FSW (still looking for its replacement)
copter
Viagra helps a
Posted: 06/20/08 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
Holy crap... I remember when you bought that. I went through your posts and found the accident. Since you posted it in towing and not all of us read those threads some of the TH folks might want to know some details. At first look I thought WW had another frame failure. Glad to see nobody was injured.
06 GRAYSTONE LBZ | MBRP 4" TURBO BACK | NOR*CALTRUCK 4-6 LIFT | AMP STEPS | 4300k HID'S | KMC DIESELS
06 COACHMEN ADRENALINE 314FS TOY HAULER | CLEAR LEDS | A&E POWER AWNING | ON BOARD AIR
05 HONDA 450R & HONDA 400EX
__________________________________
SAS!
So. Cal.
Posted: 06/20/08 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
That's good news, sounds like I still may have a warranty if I ever happen to need it.
I didn't think that nice vacuum bonding machine would go to waste.
It will be interesting to see if there will be different models for the two names.
2008 Rage'n Falcon 34-05
2004.5 RAM 3500 QC 4X4 SLT SRW CTD 600
2001 Bombardier DS 650
2001 Yamaha Raptor 660
2004 Suzuki Z 250
CORVA........The Action Program........The BlueRibbon Coalition ........aSa
dwrat
Phx, AZ
Posted: 06/20/08 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
So are you saying that WW will now have aluminum wall studs?
2BlueHeelers
Roseville, CA
Posted: 06/20/08 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
yes, some point in the 2009 model line
94fxds
Rancho Cucamonga ,Ca
Posted: 06/21/08 07:49am Link  |  Quote  |  Print  |  Notify Moderator
94fxds
Posted: 06/21/08 07:52am Link  |  Quote  |  Print  |  Notify Moderator
Is ragen going away, or are they just going to build both in the same plant?
2BlueHeelers
Roseville, CA
Posted: 06/21/08 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Both at the same plant.
