RV.Net Open Roads Forum: Tech Issues: lawn mower engine help.
 > lawn mower engine help.
Mike R.
waterford michigan
Posted: 06/20/08 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
Lawn mower wont start, fairly new on second summer. I get spark, but thought gas may be bad. disconnected fuel line and drained the gas and emptied the fuel bowl, with fuel line still disconnected sprayed starting fluid strait into the card with filter removed and still would not fire after nearly 100 pulls, someone at work suggested removeing the pull start to see if the magnito (may be spelled wrong) was lose and not lined up, does this make sense, any other tips.
Thanks, Mike R.
1996 GMC Suburban 2500 2WD 1999 Saturn
1992 GMC Sierra CC 2WD 2003 Honda Shadow Ace
2001 829s Prowler Lynx
2005 KGE3500Ti Sinemaster
Reese Dual Cam
352
Oxfofd, Fl
Posted: 06/20/08 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
sand the rust off the flywheel.
1937(BAD BOY)pontiac,all steel,chevy 350,dyno=405hp,650 holley double pumper,ps,pb tilt wheel,heat & air,
700 r4 tranny,headers,3" exhaust with flowmasters.
just a good ole southern redneck country boy.our favorite place to go to swim with the manatees
RJsfishin
Winston Or.
Posted: 06/20/08 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Is it flooded badly ? Maybe a bad spark plug?
If there is no fire at the plug wire, then yes, the mag-coil (electronic ign) may be the problem. But that requires removing the flywheel, and you may need a puller.
Thanks, Mike R.
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
Mike R.
waterford michigan
Posted: 06/20/08 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
I removed the spark plug and it has real good spark, and the guy at work said that it is most likely fireing at the wrong time, and the magnito must be out of aline, It started up good when last useing it and was running normal until it stopped after less than 1/3 was finished on my small lawn. in the 100 or so pulls while messing with it I only got about 3 small backfires.
tvman44
Southwest Louisiana
Posted: 06/20/08 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Might have sheared the shear pin and now is out of time.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
dbbls
Missouri
Posted: 06/20/08 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you are going to have to remove the flywheel. The cotter pin that aligns the flywheel may be bent. This will get the timing out of whack. Even a very small dent in the cotter pin is enough to mess things up. A backfire can cause this, or hitting something with the blade.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
Wherever I happen to park
Posted: 06/20/08 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
There are a few things needed to make it go
1: Proper fuel air mixture (Leaving gas sit in carb all winter can gum up the works, and draining won't fix, but starting fluid should have gotten SOMETHING out of it)
2: Compression, on a 4-stroke engine this involves valve timing and operation. A stuck valve WILL cause the symptoms you have.. However you can FEEL compression when you pull that roap
3: Spark, properly timed
Most small engines have a problem in this area as without exercise the points tarnish up. However you said you have good spark.. Of course you could not test timing or, more than likely, even known how to do that (And I can't tell you at this time)
Let us know what you find out
Terryallan
NC
Posted: 06/20/08 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
this is my guess as well. Don't take much to do it. Did you hit a rock, or stump? Maybe run over the dog? How about Cat
Any way it is an easy fix, at the shop.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
Mike R.
waterford michigan
Posted: 06/20/08 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
I have hit a rock in the past, but not while mowing this time, it just stopped, It is a craftsman from kmart, and I Paid around $150 for it, do you pay to fix a lawn mower that is just over a year old, or just toss and replace?
sidewinder
clover sc
Posted: 06/20/08 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
I assume you are talking about a push mower===If you have spark,it has nothing to do with your flywheel==If you have spark,you need fuel,if tou get fuel to the carb,the carb must be the problem Try starting fluid,or the someone to look at carb..
