RV.Net Open Roads Forum: Travel Trailers: Wide Steps?
JIH
Albuquerque NM
Posted: 06/21/08 11:00am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone found wider steps for their travel trailer?? I have the normal manual fold two steps. The wider dimension that I am talking about is front to back. Mine seem to be about 7". I am looking for steps about 10".
skipm
Saint Helena Island, SC USA
Posted: 06/21/08 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
I have seen extensions that bolt onto the front of each step but they were only in the 1"-1 1/2" range. It seems that these extensions had step lighting built into the as well. I doubt that you will be able to find 3" extensions that will still allow the steps to fold properly. Good luck.
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/21/08 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe bolt a 2x10 to each step platform? Or weld a 1/8" steel tread plate 10" wide to them?
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
JIH
Albuquerque NM
Posted: 06/21/08 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
The problem with extensions are if you add two inches to the top step you have to add four inches to the bottom step. However on the Jayco site (I was looking at larger trailers) I see that they are saying they have a new wider step, but they do not say how wide. I will look into that by calling Jayco. Thanks for your help.
Found what I wanted. They are Hickory Springs "Big Easy" steps. They are 10" wide and come in two and three steps.
* This post was edited 06/21/08 04:35pm by JIH *
dmzempr
ohio
Posted: 06/26/08 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Is that 10 inches wide or 10 inches deep. Can you send me the link? I was on their site but I want to make sure of the sizes before ordering. I think the 7 inch one on my Jayco is to shallow. I only have one step on the 29A.
2004 Yukon XL 5.3, 3.73, Prodigy, Equalizer 1k/10k
2007 Jayco 29A
5 campers + dog
NCHornet1
Mt. Airy, NC.
Posted: 06/26/08 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Any decent metal shop that works with sheet stock should be able to fabricate something up for you.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
