RV.Net Open Roads Forum: Tech Issues: Best Cooler?
 > Best Cooler?
TimLoon
Middlesex, CT
Posted: 06/21/08 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
I am frustrated at the inability of my coolers to keep ice more than 12-18 hours, even in moderate temps. Anybody have suggestions on a medium size cooler that can keep ice for a couple of days. We are two adults and don't open it up alot, so I know that is not the problem.
Thanks for any advice. Tim
2003 Chevy Extended Cab, 4wd,D/A, 2005 Coachman Chaparrel 275, SuperGlide
ejforwood
Littleton (Denver) Colorado
Posted: 06/21/08 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
Look at the tag on the cooler before you buy it. Brand doesn't matter. I bought one at Walmart 5 years ago that said it would keep Ice for 3-5 days in 95 degree weather. It does! Try using large chunks of ice instead of crushed. That also helps a lot.
Jerry, Dottie & Chan, "the little furry one"
98 Bounder 34V, 99 F-53 Ford V10 chassis
06 Saturn VUE 4I
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 06/21/08 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
MaxCold from Igloo Best we've found, by the end of our trip, 4 or five days we usually have to add ice, not with this! It has foam and thermal foil...I got them at walmart, fishermen love them.
tvman44
Southwest Louisiana
Posted: 06/21/08 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
Coleman Extreme 52 Qt. works for us.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
sharker6
Shelbyville, Kentucky
Posted: 06/21/08 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Coleman Extreme Marine, white with handle and wheels. I've tried many others that just don't work.
http://www.coleman.com/coleman/ColemanCom/detail.asp?product_id=6263-763
2005 Xterra off road 4X4, 2007 26' Aluma-Lite, WD w/ friction sway, Prodigy, Yamaha EF2400, 400w inverter, front carrier w/ rod holders, Dish Network
Scrib
Maplewood
Posted: 06/21/08 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
All the "Max" and "Xtreme" coolers are good (I kind of prefer the brand with the locking lid). Pick-up some plastic bread boxes at Target/Wallmart/etc. to make your own block ice. Using block ice is probably more important than the cooler - heh!
good luck!
Hurricaner
Hurricane Utah
Posted: 06/21/08 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, that and a 5 day cooler.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
GACampnGirl
Georgia
Posted: 06/21/08 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto. We have the extreme cooler. We used to use empty plastic 5-qt ice cream to freeze blocks of ice. Still used some cubes to get in and around cans etc. Worked well. Dont use much now that we have the MH tho.
good luck!
Spread the word about Campground Etiquette!
CAMPING ETIQUETTE CHECKLIST
Cybergrunt
Cedar Rapids, Iowa
Posted: 06/21/08 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
150 quart Coleman Xtreme coolers from Walmart - $80 and worth at least twice that. Load it up for a 3-4 day weekend and you will be dumping ice at the end of it.
2001 Coachmen 248TB
5880 GVWR 3768 UVW 4980 GVW 650 Tongue weight
2003 GMC
5.3/3.73
13000 GCVWR 4932 curb 1468 cargo 6400 GVWR 7800 towing 6010 GVW 10340 GCVW
21 years USMC (Retired) (Op deployments: Honduras, Desert Storm, Iraqi Freedom)
SEMPER FI!
sharker6
Posted: 06/21/08 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Quart size zip lock bags make good block ice. If you have the room gallon size works.
 > Best Cooler?
