RV.Net Open Roads Forum: Truck Campers: Receiver hitch adaptor
 > Receiver hitch adaptor
tyndalelady
Wherever we are parked
Posted: 06/21/08 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
We just bought the TC this week and now our receiver is 13 inches behind the back end of the camper. I cannot afford a superhitch, nor do I think we need that much.
Has anyone ever used one of these....
http://tinyurl.com/4fv8pp
And how did you find that it worked?
We only need to pull a 5x8 enclosed trailer. Nothing heavy.
For about $60 will this do what I need it to?
Missy
SKP# 83686
2001 Dodge Quadcab 8.0l V10 --- Miles
95 Royals International --- Betty
97 Lance Squirelite 195 --- Tex
88beast
pa
Posted: 06/21/08 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
thats a adapter for different hitches with a dodge you should have a 2 in reciever
a welding shop can make you an extention or you can just buy one as an extention
so youd need a 14 in 2" to 2" reciever extention
try any local trailer place and if its rated more than the trailer is youll be fine those are 3500# total trailer weight so if its a single ale then youd be ok
just for saftey try to find one rated more than the trailer
oh and rednecktrailersupplies.com and buyersproducts.com have etentions but im sure theyre elseware too
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/21/08 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe any of these?
16" long ball mount
14" 2x2 extender tube
18" 2x2 extender with step
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
tyndalelady
Posted: 06/21/08 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you guys so much. I am off to buy.... I like the 18 in with step. Just need to measure and see if it will fit.
Missy
dieselgrin
Virginia
Posted: 06/21/08 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Missy,
The extender cuts the tongue weight capacity down and pull capacity. I have one on my truck and works fine. Don't buy one too long (greater reductions) and remember your normal boat hitch will also make it extend further.
2002 Silverado LT, 2500HD, Duramax, Big Allison, 4x4 Crew
Bridgestone Dueler A/T Revo 245/75/16,...
Fleetwood Angler
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/21/08 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
Should be fine with her little 5x8 trailer
tyndalelady
Posted: 06/22/08 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Weight wont really be an issue. We have a tiny 5x8 trailer that will only carry what we cannot
put in the TC when we head out for extended trips this winter. Loaded for bear last January the thing only weighed 2500 lbs.
I am getting that 14 in extender.
Thanks everyone.
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/22/08 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Great! Have fun on your trip!
