karensmuzk
lake ozark,missouri
We are in Iowa right now and the misquitos are in abundance due to all the flooding. Other than getting out of here and moving on does anyone know of a good repellent or good tried and ture home remedy to keep these buggers from biting us? Or something to spray around the rv on the outside. Somehow the little tiny ones keep finding ways into the trailer.
82corvette
Southeast Nebraska
We have been using Listerine mouth wash on the deck with pretty good success
tvman44
Southwest Louisiana
I have also heard several people brag about Listerine. DW put some in a spray bottle but have not had a chance to use it yet.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Skipper Rod
Bellevue Nebraska
I purchased a propane fogger! fog all around your trailer and campsite. Works great for us
mdanielson55
frankston texas
the very best repellent is a 50/50 mix of avon sss skin so soft and alcohol mix put in spray bottle and the only bites you will get is where you DIDNT spray
karensmuzk
lake ozark,missouri
Thanks for the ideas. I'll give each a try.
Mollysmom
Iowa
Do you use full strength Listerine or dilute it ? Do you just put it in a spray bottle ? I'd love a non chemical way to keep the skeeters away - I'm in Iowa too !!
Trudy - Molly and Murphy
Waiting to be free !
Polishnurse
Schodack, NY
You can also try the GEO Methode, as the Indians did before the colonist invaded there home land. Bear grease, about 1/4" thick. they can't move there little feet and weights down there wings. Also by fall the grease will harden up enough and you know have a Misquito coat good till spring, when you reapply. Good Luck, Bill
82corvette
Southeast Nebraska
I just put it in a spray bottle full strength, it lasts a long time.
Cybergrunt
Cedar Rapids, Iowa
Another vote for Skin So Soft - good to have on hand and also helps repel ticks and chiggers.
By the way, some local environmental types are saying the skeeter population should drop significantly in a week or two. They call this current spike in mosquitoes a "post-flood bloom" - I guess you need to be a Cy-clown (Iowa State) graduate to master the obvious and coin dumb phrases like that!
Yep, lots of standing water = lots of skeeters. Duh.
2001 Coachmen 248TB
5880 GVWR 3768 UVW 4980 GVW 650 Tongue weight
2003 GMC
5.3/3.73
13000 GCVWR 4932 curb 1468 cargo 6400 GVWR 7800 towing 6010 GVW 10340 GCVW
21 years USMC (Retired) (Op deployments: Honduras, Desert Storm, Iraqi Freedom)
SEMPER FI!
