RV.Net Open Roads Forum: Travel Trailers: Power Jacks????
 > Power Jacks????
emsdad
Va
Posted: 06/21/08 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
I have a TT that weighs 3600#. I am looking to get a power jack for it. This jacking up and down is for the birds. I am looking at either the Atwood or the Barker. I like the fact the Barker has the emergency crank on the top, but I have been told its under the level and water can get in there and mess it up? I have also been told that its next to impossible to find the internal ground? The Atwood has the emergency crank but its under the white case. I can get a Barker cheaper than the Atwood. What lifting capacity should I get? I have a 2 1/4". What brand is better?
4aSong
Northwest Arizona
Posted: 06/21/08 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
Go for the largest capacity your budget will allow. Should you buy a larger TT you can transfer it over. We have an Atwood 3500 which we have been very satisfied with.
Mike and Nancy
Tundra TRD V8 4WD
Prowler 20' Lite ( The Kramalot Inn )
EU2000i * Prodigy * McKesh * Trek
samsontdog
Sac. Ca summer, Yuma Az winter
Posted: 06/21/08 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
I have had the Atwood, Barker and now a 1 yr old Ulta Fab or whatever it is called. If it was me I would buy a 3500 Atwood. They are hard to beat !
samsontdog
NHguy
NH
Posted: 06/21/08 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
I'd get one with a light on it. And get a 3500 lb jack because it must lift the rear of the tow vehicle when attached to the tongue.
You can usuallly find a good deal on e-bay.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, Battery Disconnect,
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
JTCR
Central Mass
Posted: 06/21/08 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Buy the barker made in USA and they will stand behind even when warrantee has expired.
2004 GMC 1500 4x4 Extended cab short bed 5.3 3.73
2007.5 Jayco 328RLS
campinginthewoods
Rantoul,IL
Posted: 06/22/08 05:42am Link  |  Quote  |  Print  |  Notify Moderator
Nothing wrong with Atwood jacks in my opinion but like it has been said get the biggest you can for the reasons stated.
"It Bears all Things,Believs all Things, Hopes all Things,Endures all things......Love never Fails...."
KC8WX
OH IO
Posted: 06/22/08 06:54am Link  |  Quote  |  Print  |  Notify Moderator
Same here. Got an Atwood 3500 this Spring, has a light and works well. I like the Ball Bearing Drive system. Sure makes using an Equal-i-zer much faster and easier!
Atwood 3500 Jack
2006 Durango SLT 4.7L, 545RFE, 4.10 Motive Gears with TracLoc 2WD AIRAID Cold Air Intake, PML Deep Tranny Pan, KYB Shocks
2007 Wildwood LE 27RB
Equalizer Hitch
Prodigy Brake Controller
emsdad
Va
Posted: 06/22/08 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Looks like the Atwood may be the way to go. It is a little more than the Barker but I want quality. Thanks!!
old guy
Oregon (pronounced Or e gun)
Posted: 06/22/08 10:22am Link  |  Quote  |  Print  |  Notify Moderator
if you are worried about water getting into the power head, do as I do, put a bucket over the power head and worry no more. When you get to camp, you can always use the bucket for picking berries or as a sand bucket on the beach.
GATE3303
TAUNTON,MA
Posted: 06/23/08 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
i have the barker and had to use the manual crank due to a battery problem, it woked very easily. i usually keep a plastic bag over the jack to keep water from getting in. better safe than sorry... but barker has a stellar customer support and they stand by their product..i also like the light , ive been very satisfied.
 > Power Jacks????
