RV.Net Open Roads Forum: Travel Trailers: nitrogen for tires
 > nitrogen for tires
saltbayou
hammond,la.
Posted: 06/21/08 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyone use nitrogen instead of air? Other than lasting longer in the tire are there any advantages.
2007 Tundra DC 5.7L
Reese Dual Cam,Prodigy Brake Control 2008 Northshore 295 BS-DSL
newsomer
Seven Miles South of the Cheddar Curtain
Posted: 06/21/08 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
I suggest you do a search for other postings. This has been discussed extensively.
emsdad
Va
Posted: 06/21/08 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
If the advantages are like cars, which are they will run cooler with the nitrogen, they will maintain a more consistant pressure. The disadvantages is you cannot refill with compressor air. They need to maintain at least 70% nitrogen.
mikehart92
Oklahoma
Posted: 06/21/08 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
and after reading all the posts and listening to logic on both sides, my personal opinion is that it is a way of tire shops to separate you from your money.
As posted above, you have to maintain 70% nitrogen. I thought the air you breath is about 78%. Guess my tires are already there.
Mike
Boilermakers Local 592
2005 Chevy 2500HD.............6.6 D/A, 4x4, Crew Cab
Dancing Bear
upstate New York
Posted: 06/21/08 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
I had new truck tires put on about a year ago by Dunn Tire, which uses nitrogen on their tire installations. I have not had to top off at all and stopped doing my weekly pressure test - now every two months. They check the pressure during rotations and top off if necessary. So I guess by not driving on under inflated tires, you will get better gas mileage.
coolbreeze01
Redding, Ca
Posted: 06/21/08 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
No
2008 Dodge 3500 CTD LB SRW 4X4 6-Speed Auto
P3 Blue Ox Sway Pro
2007 Komfort 212
LadyRVer
Posted: 06/21/08 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
Tire dealer put nitrogen in toad's new tires. Would not do that again!
mazdamaster
minnesota
Posted: 06/21/08 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
nascar has been using nitrogen for years, we now have a nitrogen machine at our dealership, nitrogen molecules are larger, therefore you will not lose air as fast, for every 10 degrees of temp change, you lose 1 pound of air pressure in your tires, now with nitrogen it is signifigantly less than that, the problem is that people never check the air pressure in their tires, now if you are not going to do that on a regular basis, i would run nitrogen, and it only costs like 10 bucks to put in, dont be so damn cheap, how much is your life worth?
jhomuth
Dallas, TX
Posted: 06/21/08 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
Only because we get our tires at Costco. I don't notice a bit of difference with the nitrogen though.
Jessica, Scott, and our kiddos 4 and 2
2001 Suburban 2500
2007 Skyline 247 LTD
javaseuf
Southern Cal
Posted: 06/21/08 10:56pm Link  |  Quote  |  Print  |  Notify Moderator
HERE
is 37 pages on the subject.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
