RV.Net Open Roads Forum: What Type of Caulk Should I Use
 > What Type of Caulk Should I Use
Kountryguy
Emery,SD
Posted: 06/22/08 06:51am Link  |  Quote  |  Print  |  Notify Moderator
I would like to know if anyone has found a caulk that dries with a smooth finish that dust and dirt will not adhere to. The silicone caulk I have been using seems to cure with a sticky finish. Any suggestions?
Dick_B
Palos Heights, IL USA
Posted: 06/22/08 07:03am Link  |  Quote  |  Print  |  Notify Moderator
I just Googled `caulk, no dirt' and found that Butyl Caulk dries smooth and does not collect dirt. HOWEVER, the description did not indicate that it would stick to fiberglass or other plastics; mainly aluminum. Maybe I didn't look far enough.
Maybe your local Ace Hardware would have something.
One other idea: find a paintable caulk and paint it.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Kountryguy
Emery,SD
Posted: 06/22/08 07:14am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, I'll look into that.
SAR Tracker
Sandy Eggo, Calif
Posted: 06/22/08 07:26am Link  |  Quote  |  Print  |  Notify Moderator
This stuff, available at most RV places, including CW...
ProFlex RV
Rusty & Cheryl & Serendipity (dog & Chief Security Officer)
2000 F150 4x4 5.4L/3.55 (108k miles and goin' STRONG!)
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
prichardson
Lafayette, La
Posted: 06/22/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
If you are caulking the rubber roof, your only choice is the rubber compatable ones. If you are sealing metal or fiberglass then a good choice is a marine silicone sealer.
Mousefart
New Jersey
Posted: 06/22/08 09:13am Link  |  Quote  |  Print  |  Notify Moderator
That is the LEAST of your problems. Silicone caulk should NEVER be used ANYWHERE on the outside of an RV.
Years of working on boats (both professionally and on my own boats) has taught be that silicone caulk belongs in the bathtub and NOWHERE else!
Paul (Mouse)
2007 Flagstaff Shamrock 17 Hybrid (heavily modified for boondocking and winter camping).
2007 Dodge Dakota Quad Cab 4x4, 4.7L HO, factory tow, 3.92 gears.
Equil-i-zer Hitch, Prodigy.
Yamaha EF2400 Generator (quiet, cause I care!)
