RV.Net Open Roads Forum: Severe back pain
Search only in RVing with Disabilities and Ge...
darbyjudy
New Port Richey
Posted: 06/23/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Dennis I had surgery on April 30 for about the same problem. I had a terrible pain in the left leg and the butt area, I tried the shots, therapy and everything else. finally I said I have had enough and had the surgery. After surgery I woke up with no pain. I stopped taking pain pills the second day after I came home and doing just great. I put up with this pain for almost a year and wish I had the surgery a lot sooner.
2004 Gulf Stream 36 ft Sun Voyager triple slide
Workhorse W22 8.1
2004 Saturn VUE w/stowmaster towbar
Two Ole Pharts & One Little Shin Tzu named Isabel
deanowe
long island ny
Posted: 06/23/08 09:33am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like sicatic nerve or a bulging disc,I had the same symptoms for over a year.I went to a chiro.DO not go to a Dr.they drug and cut you like they wanted to do with me!meanwhile my hip was out of wack from driving and sitting on a big wallet for years.I removed the wallet and the chiro.corrected my hip. .I would get it checked asap a disc could have slipped or be close to a rupture, which you dont want to happen!I just wanted to let other rv'ers and drivers to know; remove your wallets when sitting! your hip will form around it,Big problems!
NAVY MSC
fresno california
Posted: 06/29/08 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
rhillx4 wrote:
Sounds like you better go to the doctor and find out what is going on. Hope your better soon!
Ditto...get it checked out by an MD.
NAVY MSC Physical Therapist
NAVY MSC
F-350 LB Dually--32ft Challenger RL
Harley Davidson FatBoy
Shot of Yukon Jack
bsinmich
Holland, MI
Posted: 07/01/08 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
I had a pain like that after turning a few years ago. I happened to be at my MIL and she took me to her chiropractor. He said I had one leg shorter than the other. When I got home my Dr. found I had kidney stones. Since my wife was an RN at the hospital I got a private room as a courtesy. The only room was on the pediatric floor. Every time I was good I got a popsicle.
2003 Newmar Mountain Aire, Workhorse W22, & 2002 PT Cruiser w/Remco lube pump, Falcon 5250, & US Gear Unified Tow Brake
yakman
Carbondale, IL
Posted: 07/01/08 11:02pm Link  |  Quote  |  Print  |  Notify Moderator
Don't rely on medical advice from an RV forum. See your doctor if it does not improve or if your symptoms get worse.
Democracy is two wolves and a sheep deciding what's for dinner.
