wdigby
Manitoba, Canada
Hi
We have a Prowler 1998 fifth wheel and the inside doors (toilet door, cupboard door) need painting. What would be the best paint to use? Latex or Oil based?
Thanks
Wayne
pulsar
Lewisville, NC
Moved from Forum Technical Support.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
imgoin4it
Alamogordo, NM USA
I would use a good quality latex semi gloss paint, the same as I would in the kitchen, bath, and base boards in a stick built house. Prepare the surface GOOD before applying the paint.
Retired and loving it
Living in the Land of Enchantment
Traveling in 2007 Newmar KSDP
towing a Jeep Liberty
with a Blue Ox tow bar
RVnRobin
Pacific Northwest
People are so reluctant to use oil based paint due to special cleanup and odors. However, a top quality oil based paint is much durable, less prone to peeling, and less prone to discoloration. Oil based is the best choice by far.
RVnRobin, DW, and the cat.
The cat thinks she is the boss!
robatthelake
Vancouver Island
Depending on Your Local Regulations you may no longer be able to purchase Oil based Paint! Any Good Acrylic Latex Kitchen&Bath ( Contains Mold and Mildew Inhibitors)Paint will do! For those Doors that are skinned with that Rotary Mahogany or Prefinished Pressed Panel Board, be sure to sand and Prime with some thing like Kilz Indoor!
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
JoeChiOhki
Keizer, Oregon
Don't think I've ever come across a hardware store in the US where I haven't been able to buy oil base enamel paint. Perhaps in Canada where the regs are even more nutty than here...
Anyway, I've used both. I just used Acrylic/Laytex when I replaced the wall panel next to my dinette. I used oil based enamel on the outside. Out of the two, the oil based coats better with less paint, and holds up better. You also "seal" the surface better with a good oil based primer and top coat. The question becomes, how much work do you want to put in, and how long do you want it to last? The oil base will take a great deal longer to cure than its acrylic counter part, and will smell for a while till all the fumes are evacuated. But, once its hardened, it'll take quite a bit to screw it up again.
CB Channel 17 Space Ghost
'1991.5 Dodge W-250 Power Wagon - Club Cab Long Bed V8 5.9L 4spd H.D Auto 4x4 4.10 Gears
'1987 Pullman Mini Camper
'2004 Bi-Mart 4x8 Cargo Trailer
D & M
Laurel, MD
Agree that the oil base is better for durability and latex is easier to use. But no matter what you use, surface prep is the key to a long lasting job.
Dave & Mary
Isabel (a cuddly little Boston)
Buddy (The Beast) another Boston
2005 Itasca Suncruiser 35A
2003 Jeep Liberty
If it's listed in the Yellow Pages, the government shouldn't be messing around with it.
emtee
West Virginia
Same thing you use in your house (latex most likely). When we remodeled our 5er, we painted the interior doors and cielings, along with wallpapering all the walls. It is gorgeous and still looks like new six years later. Like was previously stated, prep work is the key. Rough up the old finish and use GOOD primer and GOOD paint.
Mark and Lucy T.
2004 Chevy 2500HD Gasser
2008 Jayco Eagle 27.5 Super Lite
Superglide on Homemade Removable Rails
HeresLucy
Southeast FL
I would put a coat of B.I.N. on it then use a top quality latex semi-gloss from Benjamin Moore or Sherwin Williams. This is what our professional painter used in our home in NC. He says the good quality latex paint nowdays is as durable as oil based.
B.I.N. will prevent any bleed thru you might get from the current finish.
Lucy
2006 Allegro Bus 40' DP
2005 Grand Cherokee
Visit Here's Lucy for CG reviews, trip experiences, etc.
Hornet28BHDS
Parker, PA
Have fun painting!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
