RV.Net Open Roads Forum: Travel Trailers: Vent Over Bed
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/23/08 03:40am Link  |  Quote  |  Print  |  Notify Moderator
My camper had a thick fabric cover that snapped over the vent opening using heavy duty snaps like from a winter coat. It kept the light out and provided a bit of insulation from cold/heat as well. It also had these covers for some of the side windows and the door window.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
Bumpyroad
Virginia
Posted: 06/23/08 04:32am Link  |  Quote  |  Print  |  Notify Moderator
my bedroom vent had an aluminum opaque lid on it, not clear plastic.
bumpy
Opie431
Bellevue, MI
Posted: 06/23/08 05:22am Link  |  Quote  |  Print  |  Notify Moderator
You could take a piece of dark fabric and apply some heavy duty Velcro dots at the cornors. Air should get thru and light keep out.
When I say dark fabric, I also mean something with a tight weave or it will not keep the dark out.
Bentstick
Vancouver Island
Posted: 06/23/08 08:12am Link  |  Quote  |  Print  |  Notify Moderator
I think that I will see if I can get the black vent cover. That's a good place to start.
The boss tried putting paper up there which work for the light, but doesn't let the air through.
2007 Tango 257 BH
2007 Dodge Ram 1500 QC Hemi SLT 4x4
subourbon
Huntsville, AL
Posted: 06/25/08 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
Go to your nearest RV Dealer and buy the foam insert that will fit into the square vent opening or go to Wal Mart and buy the foam and cut to size. works great.
Happy Camping
2007 Chev. Silverado CrewCab 4x4
6.0L Vortex Max
3.73 Rear Axle Ratio
Prodigy Brake Control
Equalizer Hitch
Champion 4000/3500 30A RV Gen.
Garmin 7200 GPS
2008 31E Jayco Feather LGT
UVW6225 GVW7850
ROBINS NEST
zndad
Hermitage,Tn
Posted: 06/26/08 07:52am Link  |  Quote  |  Print  |  Notify Moderator
We have a vent over our master bedroom in our Max-Lite and I purchased a vent cushion at Camping World. It fits snug into the vent. It keeps the light out and easy to use. I also bought another one for my other vent. Makes a big difference. I paid around $15 for two.
zndad
greyeyes819
Eastern, PA
Posted: 06/26/08 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Cybergrunt wrote:
BarneyS wrote:
Get one of these in the dark smoke or black color. It will allow the air to circulate AND keep out the light. You can leave your vent open 24/7 all year long! Nothing will get in except the air.
If you have a high efficiency fan in the vent, then get one of these.
Barney
I second that idea - in fact, I resemble that idea. We have a ceiling vent directly over our master bed. It was nice at night, but more than a bit annoying in the morning according to the boss. She wanted it solved and I invested in the black MaxxAir vent cover - problem solved as much as possible. The only other option would be one of the velcro or snap covers.
I agree as well. We put the black one over our bed. Works pretty good.
Tami, Daniel
Owen & Ethan
05 F150
07 Sunset Trail 30BH
Reese Dual Cam & Prodigy Brake Control
KLO
Southern OK
Posted: 06/26/08 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Another idea is to make a cover using solar screen. Cut to fit then use Velcro to attach to the inside frame of the vent. It will let air thru and should darken the room.
shadows4
Kansas City, Mo
Posted: 06/27/08 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Happy Camping
This is what we did. Used a piece of foam from and old kitchen chair cushion, cut to fit.
2000 4X4 Excursion Limited 6.8V10, 4.30, 122,000 miles
Hellwig Rear Sway Bar
Roadmaster Active Suspension
2004 4X4 Expedition 5.4V8, 3.73 210,000 miles
2000 Coachmen 297 RKS
Reese Dual Cam Sway Control
Rubiranch
Salt Lake City, UT
Posted: 06/27/08 07:54am Link  |  Quote  |  Print  |  Notify Moderator
I don't think I owuld like a vent over my bed either.
That would sure be an easy one to miss.
TV: Mint 1972 Ford F-250 XLT
TT: 1969 19' Excel; entertains 6, feeds 4, sleeps 2
You don't shoot to kill, you shoot to stay alive.
I don't carry because I have to, I carry because I get to.
I like new things-
- when they're 40 years old!
My pictures
