RV.Net Open Roads Forum: Generator Dies when start button is released
 > Generator Dies when start button is released
j-d
Sunny Florida USA
Posted: 06/26/08 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
By "elevation" you mean "altitude?" Our BFA Spec C does not have that adjustment, but it does have high and low mixture adjustments on the carburetor. The tension of the choke spring/element is also adjustable.
Let me know what your model is.
God Bless, jd
The LeRoys
St Petersburg, FL, USA
Posted: 07/02/08 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
I'll get the Model and try to snap a picture this weekend for you.
Also going to see if I can squeeze my arm back enough to be able to reach the back plug, didn't think I could last time I tried. Do you have to remove anything to reach yours?
yes, I meant Altitude.
Any luck on getting yours to stay running when letting go of that button?
Brian & Evie LeRoy
Bryanna and now MaryAnne (born Oct 2007)
1989 26' TravelMaster Signature GS Class C
2 Dogs (Akita and German Shephard)
2 Big Birds (Cockatoo's)
& our Wallaby (in spirit only now)
LeRoy Home Page
The LeRoys
Posted: 07/06/08 09:14am Link  |  Quote  |  Print  |  Notify Moderator
OK, I went out to the generator yesterday and took a look. The altitude setting goes from 0 - 10K ft, which is about 1/4 turn. Adjusting it doesn't seem to help or change anything.
To get it to start, I have to hold the manual choke down. When it starts I get a ton of white smoke for the first little bit.
After it starts, it idles high for a second, then tries to idle down as low as possible and stalls out. If I hit choke right before it dies, it will rev up again and stay running. It will then run for a few seconds, before it tries to idle all the way down again. I go through this for a few cycles before it stays running at high idle.
When a load is on the generator (always), then the throttle pretty much runs wide open.
I think maybe the "autochoke" isn't working as it should. I popped the front of the round case, and found it has 2 terminals, and a face like a clock with tick marks all the way around. 2 Arrors, lean (clockwise) and rich (counterclockwise). I'm not sure how this should be set.
My model # is a 4BGEFA266100F
midnightsadie
ohio
Posted: 07/06/08 09:48am Link  |  Quote  |  Print  |  Notify Moderator
might change the gas filter, sounds like its starving for fuel.
The LeRoys
Posted: 07/06/08 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
No fuel filter. I bought the one that is made for my model, but I don't have one in line on this guy.
The LeRoys
Posted: 07/08/08 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
Any ideas on those autochoke settings for my model?
Could that be your problem as well Traveling4Sports? Have you gotten anymore information?
Traveling4Sports
Posted: 07/09/08 07:00am Link  |  Quote  |  Print  |  Notify Moderator
RV repairs have been on hiatus for a few weeks as I am having some work done on my house. I plan to work on the generator next week. I will keep you posted.
chris85am
Fleetwood, Pa
Posted: 07/09/08 11:13am Link  |  Quote  |  Print  |  Notify Moderator
since it has no fuel filter could it have gotten some dirt into the carb and not letting all of the fuel it needs at idle.
2004 Coachman Leprechaun 317KS
2008 Jeep Wrangler Rubicon, Blue Ox towbar & baseplate, Brake Buddy
midnightsadie
ohio
Posted: 07/09/08 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
wonder if the start button went bad??
The LeRoys
Posted: 07/22/08 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
No one has a suggestion how to adjust my auto-choke?
