RV.Net Open Roads Forum: Class C Motorhomes: Alcoa Wheels
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > Alcoa Wheels
TexGeorgiaBoy
Fort Worth Texas
Posted: 06/22/08 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
My 2008 Seneca has aluminum wheels. Pros and Cons? Why do the steel valve stems face backwards into a hole in the wheel? That makes air checks and adds a major task. Any solutions to that? Thanks, Tex
Rollincool
Always Rollin
Posted: 06/22/08 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
This
and any one of these
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Conquest Super C 6349
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
My 70's Show - Tom Kent Radio Network - K•Hits 106.7
Gene in NE
Omaha, NE
Posted: 06/22/08 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
Or...TireMan .
2002 Trail-Lite B Plus 211-S w/5.7 Chevy
Gene
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 06/22/08 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
Alcoa are the best of the best, forged in the USA from a block of 6061-T6 Aluminum by a machine that applies up to 50,000 tons of pressure to form the wheels, which are 423% stronger than steel, and twice as strong as cast aluminum wheels. The same presses make M1A tank wheels, the Space SHuttle wheels and Jumbo jet wheels.
Jayco really didn't cheap out on your RV's wheels! So that would be a big "Pro!" And no "cons!" We are looking for our 8th Jayco right now, waiting for the new Embark to show up, or maybe a Seneca! Good luck!
Westronics
Redmond, WA
Posted: 06/22/08 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
fordsooperdootydieselsmoker wrote:
... So that would be a big "Pro!" And no "cons!" ...
Agreed. We'd all have them, I think, but for the expense. Consider yourself lucky.
2002 Jayco Greyhawk 24SS, Cameras (RVCams), ScanGauge II/Blendmount, 300W Inverter, Airtabs,12' Portabote w/sail, Be kind to septic systems.
Ford motorhome customer service: 1-800-444-3311.
Fulltimers
Anywhere, USA
Posted: 06/22/08 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
I saw where one person had dismounted the tire and loosened the valve stem and turned it around. Now it faces out.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2001 Saturn SC2 (Mr. Toad
Photos
ronfisherman
SE Michigan
Posted: 06/23/08 04:03am Link  |  Quote  |  Print  |  Notify Moderator
Alcoa has air gauges and valve stem extensions on their site. Alcoa Aluminum Wheels. They also have supplies to care for your wheels. They do not sell these products. You need to use their search to find a dealer.
You can also add stainless steel braided extensions.
Removing the front caps can be a problem. Because the stem caps are set inside hole. Here is a tool that works Valve Pal. Others have made one from rubber hose and a wood dowel.
I purchased a valve stem chuck and gauge at a RV rally like these displayed on Alcoa's site.
Models 003500 and 001605.
Saf-TTE tire monitor
az99
N.Y.
Posted: 06/23/08 05:18am Link  |  Quote  |  Print  |  Notify Moderator
There is one con. Cleaning and polishing non clear coated wheels. Even with the best polishes and a powerball it is still a time consuming PITA.
Rich Panganiban
Southern California, USA
Posted: 06/23/08 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Al, I need to polish my Alcoa wheels. Any suggestions? Thanks.
2007 Jayco Greyhawk - Kodiak 32SS
'00 Subaru Outback Wagon
ron.dittmer
Near Chicago
Posted: 06/23/08 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Alcoa wheels simply look great, increasing the sense of quality of an RV, and I understand they are made with the best of workmanship. But......how would a motorhome benefit in practical ways? Is there a significant "Unsprung" weight reduction that would improve the quality of the ride? What are the weight differences between the two types of wheels? Alcoa wheels should be better balanced compared to stamped steel, but RVs generally cruise at slower speeds for fuel economy, thus reducing the benefit of the perfect balance of wheels.
I would think there is nothing to gain except for styling, but would love to hear your opinions on the "practical" benefits of the Alcoa wheels compared to stock steel with covers.
Bought new in June 2007, Phoenix Cruiser-2350
Fits inside our garage.
Dingy towing a red Toyota MR2 Spyder
See The Inside by clicking on "View Profile" and scroll down
 > Alcoa Wheels
