RV.Net Open Roads Forum: Travel Trailers: Black Water Tank Doesn't Drain Well?
 > Black Water Tank Doesn't Drain Well?
AlaskaCub
Alaska
Posted: 06/22/08 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
Well I just returned from my first road trip with the Jayco and it performed as good as could be expected. The only thing I dont understand is that the Black water tank says its 2/3 full and yet when I open the dump very little water comes out (maybe 1/2-1 gallon). I even poured several gallons of water in the toilet to see if it would flow through but it just trickles. Any ideas???
wtravlr1
Palm Harbor, Flordia, and Geneva-on-the-lake, Ohio
Posted: 06/22/08 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
Probably sensor problem, notoriously bad. In reading the post, it looks like you might have a clog in the exit pipe. You try something like Rid-X that grows bacteria that eat up the black matter, but it takes time, or maybe use a Flushking to try to backflush the exit drain from the tank.
2007 Forest River Sierra 31fkd (37') dual slides
chevy suburban 2003 2500-8.1 L.4.10's
prodogy/reese dual cam
rollgard springs
Fulltiming it since 2004.
My Homepage and Rv pics press here
swebber
Brunswick , MD
Posted: 06/23/08 04:50am Link  |  Quote  |  Print  |  Notify Moderator
wtravlr1 wrote:
...... In reading the post, it looks like you might have a clog in the exit pipe. You try something like Rid-X that grows bacteria that eat up the black matter, but it takes time, or maybe use a Flushking to try to backflush the exit drain from the tank.
Ditto the backflushing idea.If it only trickled out then there is a clog at the gate valve.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
NCHornet1
Mt. Airy, NC.
Posted: 06/23/08 05:22am Link  |  Quote  |  Print  |  Notify Moderator
The black sensors are notorious for false readings. If you understand how they work you will know that all it needs is a very small wet piece of TP or ??? and the sensor will read full. Ridex will do nothing as your waste better not be in there that long!! Ridex is for septic tanks not holding. Do a search for the Geo method, follow it and use a flush king. Trust me I grew up RVing and have had several myself and I have tried everything and this combo is the best.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
tvman44
Southwest Louisiana
Posted: 06/23/08 06:47am Link  |  Quote  |  Print  |  Notify Moderator
Use the Geo method, and follow up with the flush king.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
neilmccu
Calgary, Alberta
Posted: 06/23/08 08:22am Link  |  Quote  |  Print  |  Notify Moderator
My Jayco does this all the time buy a flushking, which I haven't yet. It's better than having to stick a garden hose up the pipe and wait for the FLOOD of "xyz" to come out and put the drain back on.
MoogRat
Dallas, GA
Posted: 06/23/08 08:30am Link  |  Quote  |  Print  |  Notify Moderator
We have a Jayco and had the same problem, started to even get odor inside unit and was about to replace the toilet. Spouse stuck hanger up drain exit from the outside the coach and guess what came out? When the tank was drilled they pushed the circle back into the tank so everytime we tried to drain all that came out was the fluid! Sometimes we wonder if this is why even our gray tank seems to empty so slow now.
TheBeans
Bonney Lake, WA
Posted: 06/24/08 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
We had the opposite experience when our Jayco was brand new. The black tank valve was fully closed but was leaking out anyway! Yuck! So, back to the dealer, who took a look around and found that the circle of wood (mentioned above as being drilled out) had indeed been left and not removed but had jammed the valve into the 'open' position and wouldn't have closed for anything unless it was removed. Which they did, and now everything works great.
Oh, and the Geo method has kept our sensors reading as they should. Can't recommend it highly enough.
me
Darrell
2 doggies
2005 Jayco Jay Feather 25RKS (aka: The Bean Pod or BP3)
2007 Ford F150 (aka: Rosita)
Capt-Ron
Down South in the Palmetto State
Posted: 06/25/08 08:08am Link  |  Quote  |  Print  |  Notify Moderator
My black tank had a habit of plugging up and I used my Blue Boy to clear it.
After hooking a short hose and opening the valve I would step in the middle of the Blue Boy and the air pressure would clear the clog and the blackwater would flow. Then I'd open the vent cap and continue to drain the tank.
This way there is no mess and it actually works like a reverse toilet plunger.
CaptRon
2003 F-350 CC, LB, 6.0L PSD, 6SP Manual, DRW, Kelsey-Hayes 81740C hydraulic brake controller.
Paralleled Honda Eu2000i's
No Longer Full Timing After 5 Years!!!
JeeperAz
Az
Posted: 06/25/08 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Same as MoogRat.
After one the first few trips in our trailer, I was filling my black tank via a flush king. I was looking down the toilet with a flashlight(dont ask why) and noticed a roughly 4" circular piece of plastic float by. This was obviously the cutout piece when the factory did the plumbing.
A few trips later when flushing, this piece actually came out and lodged itself in a clear elbow attachment I was using.
Could be your problem.
* This post was edited 06/25/08 12:25pm by JeeperAz *
'06 GMC 2500HD Duramax(LBZ)
'06 Ragen FB2500
Larry & Mindy
Backseat: Maya (black lab)
