RV.Net Open Roads Forum: Fifth-Wheels: Pin Box Air Ride Couplers
 > Pin Box Air Ride Couplers
tomthyme
Flower Mound, TX
Posted: 06/23/08 05:22am Link  |  Quote  |  Print  |  Notify Moderator
Hello Again,
My loveley bride and I are back from our first weekend in the new right and I have a couple of questions for you veterans out there.
Question One: While the 2 hour drive was reasonably comfortable we were wondering what opinions there might be out there on the effectiveness of air ride couplers (such as 5th Airborne). The jerking wasn't bad, but it was certianly noticable and could get uncomforable for longer drives. Does anyone have an opnion here?
Question Two: For some reason, we keep blowing one 20amp fuse that is wired for the kitchen lights. We've got it on the delivery punch list for dealer repair, but is there anything I can do in the interim? Perhaps I could shove a 30amp fuse in the slot. Is that good, or bad?
Question Three: The kind gentlemen who delivered my coach to me never closed the valves on the black/gray tanks. So I go to empty my tanks for the fist time and....well you can figure out the rest. we laugh at it now, but at the time it wasn't pretty. Now, of course I've got the "close the valves" step on a pre-departure check list, but is there a way to sanitize the tank drain pipes (since they served as holding tanks for two days)? Of course I had chemicals in there, and I did shove a 10lb bag of Ice in there with chemicals and dumped again after a few miles, but I didn't know if there was another trick I hand't tried.
Thanks to everyone for the help!
By the way, we loved the weekend, even with the unusual experiences. We can't wait until the 4th!
Tom, Sarah, Nick (Border Collie), Olive (very large feline)
2005 f350 2wd lwb drw 6.0l
2008 31' denali
Bill1374
Saratoga Springs, NY
Posted: 06/23/08 06:17am Link  |  Quote  |  Print  |  Notify Moderator
Can't answer 1 for you but....
2. Assuming you're talking about a 12 volt system, then it's not a good idea to go the a 30 amp fuse. Find the short that causing the problem. Could be one light is bad. If it's a 110 system, it may be as simple as a bad breaker.
3. Pipe is really not going to be a problem. When you rinsed the tank with the gray water and then clear you took care of the problem. However, I suggest a change in your list. The black valve should never be open unless you are dumping. And normally, don't dump with less tha 3/4 of a black tank. If you are just weekending, add water to the black before you dump and head home.
Bill
2000 Hitchhiker II Rio Grande
2000 Dodge 3500 dually Cummins 5 speed Edge EZ and guages
RCMAN46
NorthWest
Posted: 06/23/08 06:57am Link  |  Quote  |  Print  |  Notify Moderator
1. As for a Fifth Airborne I just finished my third trip with one. The only problem I can see is it is so smooth I forget the trailer is behind me. With a P3 brake controller, the Fifth Airborne and a DMAX diesel most of the time there is almost no feedback from the trailer. About the only thing that has much response is the fuel gage.
MBOK
SE Texas
Posted: 06/23/08 07:05am Link  |  Quote  |  Print  |  Notify Moderator
1. 5th Airborne is great and RCMAN46's analogy is right on.
2. If its in a slide out check for a nicked wire on the underside of the slide. Have had that happen twice on two different units.
3. solution w/bleach sprayed into will work but i wouldn't worry about it
'06 Truck LWB DRW - '07 37' 5th Wheel
glsurrat
Virginia
Posted: 06/23/08 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
1. Have you looked at a TrailAir Pinbox? Probably a cheaper, smaller solution with the same results.
2. If you put the 30 amp fuse in, some other 20 amp component in the circuit will burn out - and if it happens to be a wire that gets hot, it could catch something else on fire before it burns in two. Find the problem and fix it properly.
3. I wouldn't worry about sanitizing the line. It will get plenty of rinsing out the more you use the trailer and drain the gray water tank.
Greg
Full-timing and soon to be retired US Navy Master Chief
Enjoying Champagne on the King Ranch!
'06 King Ranch F-350 Dually Diesel 4x4 Long Bed Crew Cab w/ Tow Boss
'07 Champagne Edition NuWa Hitchiker 3 axle 4 slide 37CKRD /w TrailAir all around
SteveB
Rhode Island
Posted: 06/24/08 10:18am Link  |  Quote  |  Print  |  Notify Moderator
1: Another 5th Airborne owner. It worked out great for my setup.
2: A screw could have nicked a 12V wire. Putting in a 30A fuse is BAD.
3: What everyone else said.
Happy new camper!
SteveB
'01 Dodge Ram 3500 CTD HO 6sp, Reese 15K Pro w/ Kwik Slide, Prodigy
'04 Jayco Jayflight 28.5RKS
ozhoo
Anza Borrego Desert
Posted: 06/24/08 10:38am Link  |  Quote  |  Print  |  Notify Moderator
I always get a kick out of this comment. If you forget that a 30+ foot rig is behind you, then you probably lost it somewhere along the road.
I too run a 5th Airborne and while it certainly helps, I always know it's there. And even with a 5thA, some roads will still beat the black water out of you.
O
2003 F350
2003 KZ36P2
650 watts of solar feeding (2) networked Blue Sky 3024i CC, charging 660aH Lifeline AGM bank
Know before you tow- Towing Laws by State
Energy conservation is 5-10 times the value of generation. Check your appliances at EnergyStar.GOV
Cat320
Western AR
Posted: 06/24/08 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Yep, 5th Abn works fine.
countryrose
Redding, Ca
Posted: 06/24/08 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
My travel buddy has the Airborn and I have the TrailAir He claims his works great and I feel the same way about my TrailAir. I would check in the cost before making my decision. As for how well they work, they are great. I was talking to a guy you transports FW from the factory to the dealers and he had just delivered a FW with the TrailAir pin. He said "I have probably delivered over a hundred FW and this is my first with an Air pin Hitch and the difference is remarkable". Trust me though you will never forget the trailer is back there. there several brands on the market including MorRide, TrailAir, AirBorne.
Good Luck.
stevep7
nc
Posted: 06/26/08 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
just recently put the Trailair unit on.I couldn't be happier.Have to mess with the air pressure a little to get the perfect ride but once you do you will be very satisfied
