RV.Net Open Roads Forum: Towing: HELP! How to un-hitch my Jayco?
Search only in Towing
Open Roads Forum  >  Towing
 > HELP! How to un-hitch my Jayco?
htt07rv
Albuquerque
Posted: 06/23/08 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Since installing my Equal-i-zer I have had a difficult time un-hitching my 2007 Jayco Jay Feather Ex-PORT 17c from the Equal-i-zer ball. What happens is the Jayco hitch (lock/release lever) will not lift up and over the ball mounting location. The setup is rather new...just a 2007...and kept very clean.
Does anyone have suggestions on the best way to get it to release? Should the Jayco hitch lock/release lever be lubricated?
Thanks for all your help!
htt07rv
* This post was edited 06/23/08 03:42pm by htt07rv *
Family of 4...that LOVE the freedom of camping.
newsomer
Seven Miles South of the Cheddar Curtain
Posted: 06/23/08 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
Is it just not releasing from the ball or is it just not able to lift high enough?
If it's height I have a similar problem with our new trailer so I just put two of the Lynx Leveler blocks under the tongue stand so it'll lift higher. It's not a matter of the Equal-i-zer ball, it's just a smiple 2 5/16 ball but I do find that the new trailer has a harder time dropping completely on to the ball. I had no such problems with our previous trailer, both made by Starcraft.
2007 Chevy Silverado extended cab, 5.3L, Z85 - 2008 Starcraft Travel Star 27RBH - Equal-i-zer
To Infinity, and Beyond!
Our Campsites (Live Maps)
alpenliter
Olympia WA
Posted: 06/23/08 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Shoot some WD-40 in there to loosen it up!
2004 F-450 CC, DRW 6.0 Classy Chassis
1997 33' Alpenlite St. Andrews
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Alpenlite Travel Club #5955
Vietnam Vet '67-'68
Extreme Makeover RV Style! Click here!
c.traveler2
Moreno Valley,Ca.
Posted: 06/23/08 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
After hitching up your trailer to the TV,use your trailer jack to lift up both the rear of the TV and trailer touge. This will put the wd bars in a much easier postion to hook up,do the reverse when unhooking. This is what I use to do when I had a TT and my neighbors do the same.This will also work on a sticking trailer hitch.
2007 F-250 4x4 /6.0 PSD/ext cab/LB/camper pkg..Lance 815 ext. cabover
Get the camper you like and fit your needs
Alex and Julie's travels
Travelingman2
RV dump search
Recreation.gov
campground reports
donn0128
Pronounced Ore-gun
Posted: 06/23/08 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
Also, if you simply cannot get the latch lever to move, try pulling the TV foreword just a bit to unload the latch.
Donn
Dmanos
Newcastle, TX
Posted: 06/23/08 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
Everything that moves or has metal-on-metal contact should be lubricated.
Turbo Diesel Dude
Green Mountain, NC
Posted: 06/23/08 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe the hitch ball is too large ? Some have an adjustment nut under the hitch that may need to be loosened for the latch to move. A 3 ft crowbar may be called for. Check for proper ball size when you are able to get it to release. Trailer should have the ball size stamped on the front near the latch.
charles weidman
redsb3
Tucson
Posted: 06/23/08 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
Jayco uses that stupid reverse coupler. I still have trouble getting the ball to slide out sometimes. Usually you have to pull the tow vehicle forward just a smidge and it will drop off. Just make sure your TT is chocked real good so it doesn't move. It is the only thing I hate on my Jayco.
2005 GMC Sierra SLT CC/SB with 6.6L Duramax/Allison
2006 Jayco Jayflight 28FKS
Putnam XDR class V hitch
Reese Dual Cam Straight Line hitch
TURK2500
S.E., Michigan
Posted: 06/23/08 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
redsb3 wrote:
Jayco uses that stupid reverse coupler. I still have trouble getting the ball to slide out sometimes....snip
I've owned a couple of Jayco TT's and never had any problems with the couplers. I do however keep the ball and coupler lubricated as mentioned in prior replies.
Turk2500
05 Jayco Eagle, 278FBS, UVW 7,063lbs, GVWR 9,000lbs.
Tongue Weight: Dry 913lbs/Loaded 1,200lbs.
02 Chevy, 2500HD/4x4, 6.0L/4:10, EC/LS/SB, Prodigy, GCWR 16,000lbs.
TV/TT loaded: 14,700lbs.
Putnam XDR Class V, Reese HP Dual Cam.
00 HD Road King Classic.
htt07rv
Albuquerque
Posted: 06/23/08 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
It just will not release the ball when I am trying to un-hitch. I've tried where the receiver and hitch are at travel height...and also lifting the hitch up...to try and have the hitch lock/release lever release. But that thing is stubborn! Most of the time...I cannot even get the lever to move. Don't like this hitch on the Jayco...
htt07rv
