Tex Garcia
So Cal
Toy-hauler wrote: I bought mine from Allied Battery in Seattle. They had new batteries out of a totalled genie hi-lift that never went into service.
Good deal!
Genie OEM is a t-105 but Genie also adds an oil to the cells that helps the battery keep from going dry. You should get years of service out of them. You scored!
Tex
00 FREIGHTLINER c16 cat 18 SPEED
04 F-250 PSD, TORQUE SHIFT, CREW CAB FX4
05 VORTEX 365TB-SS-FW
77 WIFE
05 DAUGHTER
00zx6r
Ca
The Sams club 6v last 2 years for me now I bought 2 12v Maxx 29 rated 125AH at Wally World.
2001 E450 Fourwinds Majestic 26
2004 Dodge Durango Limited Hemi 4x4 LO
2005 18' Haulmark enclosed trailer
2005 Honda CBR1000RR Resol
2004 Honda CBR1000RR Silver
2002 Honda CR250
2005 Honda 250 Recon ES
2002 Honda TRX90
2000 Kawasaki KX 250
Lake Laurashawn
Carlsbad CA
...Genie also adds an oil to the cells that helps the battery keep from going dry...
What are the specifics on the oil and who else out there adds an additive to batteries?
2001 Chevy 2500 8.1/Allison 4:10 Crew Cab Long Bed
2004 Weekend Warrior 5'er
Tex Garcia
So Cal
Lake Laurashawn wrote: ...Genie also adds an oil to the cells that helps the battery keep from going dry...
Not sure. But I received a newsletter from Genie some time ago stating that they use this stuff in every battery that leaves the factory.
http://www.thermoilbatteries.com/index.p........m_content&view=article&id=124&Itemid=173
I have not purchased any yet. But in the rental business I see what holds up too abuse. The batteries in Genie electric lifts tend to hold up better than anything else I have seen so far.
Tex
Lake Laurashawn
Carlsbad CA
Thanks Tex, I would be interested to get a few bottles and at the next time I need to add water, add that to one on my battery banks and fill the other bank with distilled water as I always have. I already have several years of good service from my current set-up and would be interesting to see how it worked for the next couple of years.
barry&vanda
Vancouver BC Canada
Just buy a small bottle of MINERAL OIL from a drugstore. Half teaspoon in each cell. Works great. Floats on the electrolyte & makes a barrier against evaporation.
Honk at any red Dodge Ram & Crossterrain toyhauler on Baja. It's gotta be us - 'specially if it says Baja and Back #1.
AreYouKiddingMe
SoCal
Tex...do all the electric aerial lift manufacturers use the same battery? (JLG, Genie, SkyJack)..One of the companies I used to drive for is an aerial only equipment co.
Tex Garcia
So Cal
AreYouKiddingMe wrote: Tex...do all the electric aerial lift manufacturers use the same battery? (JLG, Genie, Skyjack)..One of the companies I used to drive for is an aerial only equipment co.
On the smaller lifts (19', 20', 26' electrics) they use the T-105
On bigger lifts (electric booms and some 26'& 32'scissors) they use the J-250.
I don't own any Skyjacks or JLGs. But I think Skyjack uses Trojan batteries. I am mostly buying Genie & Snorkels right now.
The spec on 6-volt batteries in aerial equipment will be the same. The battery is used as counterweight so if the battery is an approved OEM replacement you are getting the better battery. Some manufacturers make a golf cart battery(ie Exide E-3600). This battery is the same in every way but is 1/2" shorter in height and weighs about 10# less. Although a good battery it will have a bit lower amp hr rating (186amp Hr). The batteries found in AWP will have an amp hr rating of 220 or better.
Tex
MCrankyPants
Dayton OH USA
If you have a Batteries Plus near you, they carry a monster 12v battery that has a ridiculous amount of amp hours...I wasn't smart enough to write the model number down, and their website is less than user-friendly, but the amp hours were significantly higher than two T-105's which I've used for years.
Would be worth a trip to their store if you have one near.
2007 Teton Experience Sunrise pulled by 2003 Dodge 3500 Cummins HO 6-spd. 4x4
'61 VW Double-Cab
