jason shaw
australia
I need to wire in extra side markers on my W/W SL2805. (this is not by choice.) It is another requirement over here. I need one each side some where near the middle.
The problem is running the wires to it. Is it possible to get a wiring diagram?? Or better still is there such a thing as a workshop manual.
I'm hoping I may be able to pull a wire through from 1 of the front or rear markers and If I disconnect a power point and pull it through on the power wire with a string to pull power wire back.
Anyway a wiring diagram would be real handy so I can see where the wires go and if or what I could hook up to.
Any thoughts or help would be much appreciated
nny12972
NY
If I were you, Jason, I'd drop a note to the mfg. C/S folks .....ask them for the construction detail drawings and wiring diagram. I've been able to get them for every rig I've ever bought.
J
carringb
Corvallis, OR
jason shaw wrote: I need to wire in extra side markers on my W/W SL2805. (this is not by choice.) It is another requirement over here. I need one each side some where near the middle.
See if Weekend Warrior will send you diagrams on their repair. It's actually required in the US as well (if actual length is greater then 30'). WW was out of compliance, and has issued a recall to add center side markers.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, 230,000+ miles
Had: Weekend Warrior 41' FSW (still looking for its replacement)
Macs Dad
SoCal
Man if you get wiring diagrams from WW let me know. I want one to.
07 Weekend Warrior SL2805
05 Chevy 2500 HD Crew Cab 6.0/410 Gasser
05 Honda 400 EX
07 Twister 150 GT
03 Honda CR 125
nny12972
NY
FR's C/S has been great with me.......very detailed structural drawings, electrical diagrams---and they were correct...everything I needed to locate and/or avoid when making mods & fixing things........FWIW: My dealers also maintained copies of drawings for all the rigs they sell.
J
jason shaw
australia
Well I got no reponse from W/W with my email request for wiring diagram.
Anyway I attacked the job of fitting extra side markers, and it wasn't that bad. I removed a rear power point and fed a flexible plastic rod up the side to the next P/P. Then tied wire to it and pulled back through.Then went out side drilled hole fed coat hanger down and pulled wire up. fitted the extra side marker and replaced all the others to LEDS, I'm now lit up like a Xmas tree.
Woodsrider450
Great Lakes
nny12972 wrote: If I were you, Jason, I'd drop a note to the mfg. C/S folks .....ask them for the construction detail drawings and wiring diagram. I've been able to get them for every rig I've ever bought.
I called c/s to request construction/wiring diag. for my jayco octane and the gal said they won't send them to me because i'm under warranty...???
edited 06/25/08 11:44pm by an administrator/moderator *
jackxclan
bakersfield
make sure to post some pics of that WW in action down under.
Gun metal gray 07 new body style 3500 diesel crew cab 4x4 dually
red WW fsc 28 tiki hauler
red 400 ex
black 250ex
red 400ex
red 250ex
red KW heavy iron hauler
HOOLIGAN # 385
