cdcorn1
CA
I too have a 2003 Rage'n 30-5G. The night stands pull away from the wall when the weight is on the kingpin. So far the gap is only about 1/4 inch max. The bed hinge looks good so far.
2002 Chevy 2500HD, Duramax/Allison, CC, SB
2005 Yamaha Rhino
2003 Rage'n 5G
2002 XR650R (Street legal)
2002 KX250
2003 CFR230 (Street legal)
2002 KX100
roach1
Canyon Country, Ca. USA
The damage you are seeing my not be a "Pin Box" issue. I have a 2006 FA 3405 (aluminum side) and was seeing the same thing with the night stands. Plus, one of the bedrooms interior walls had a 6 inch horizontal crack that started at the edge of the bedroom window and most of the corners in the bedroom were spreading apart.
Anyway, I took my trailer down there and told them about the pin box concern. I was told that prior to the 2007 models, they would only screw the walls down into the frame. This caused some "flex" in the walls, which they told me caused anchor bolts to break off or the walls base board to crack. They now, I mean were, welding a large piece of angle iron to the frame, so they could drill both down into the frame and in from the side of the angle iron. They said this really increased the rigidness of the walls and since doing that, have not had any reports of similar types of damage.
Unforunatlly this was no small job, they had to completly remove the entire front bedroom of the trailer to expose the frame to were it begins to angle down. They then welded the angle iron to the frame and put it all back together. I have only had the trailer out twice since the repair (4/2008) and every thing seems to be holding together........for now anyway.
This is just something else you should look into.
Roach
The Roach's:Jim, Lisa, Jess, Megan, Buddy(boxer), Cujo(mutt), Bella (Pomeranian)and Dolly(Chihuahua).
2007 Ford Super Duty
2006 Rage'n Toy Hauler
2006 KTM 525 EXC
2005 CRF 230
2004 CRF 230
2004 TTR 125L
Don't sweat the little things in life
cdcorn1
CA
Thanks for the info. I'll have to check the walls for any cracks.
cobyco
Thousand Oaks, CA
I Have an 2006 3005 Fiberglass sides Zero Problems with pin box, cabinets or bed SO FAR. I run a reese 18K signature series hitch which swivels all directions so maybe helps lighten the stress, Has anyone else with an 06 Fiberglass had problems with pin box ? Thanks Coby.
2006 RAGEN 3005 5TH
1999 DODGE 2500 V10
Firestone Airbags
Awsome Wife
2 yellow Labs Cooper & Kona
2001 WR 250 mine
2003 CRF 230 wifes
2006 Twister HammerHead SS
2BlueHeelers
Roseville, CA
Yep, I have same year/model and in 07 took mine in for new gussets to stop the bedroom furniture gap and front cap creep.
All solid now ... knock wood!
Rage'n FA30-5
Chevy D/A
KFX700
Scrambler
cdcorn1
CA
Is this repair/fix something the local dealership can do? How much did the gusseting cost?
Thanks,
Chris
2BlueHeelers
Roseville, CA
My work was completed under warranty at Ragen.
socalrider
carlsbad, ca, usa
Mine was also repaired with the gusset at Ragen, covered under warranty. A year later and no issues with the nightstands or cabinets.
nayther
Burbank, CA
Reading this explains why they took the siding off one side when I took it in for warranty work at Rage'n. Guess they might have fixed it?
DIRT BIKES RULE
'05 Duramax CC short bed
'06 3005 Rage'n Falcon
cobyco
Thousand Oaks, CA
Does anyone have any pics of all thses repairs, I have some movement in nite stands about 1/4 inch off wall at center sides when hooked up and flush to wall when un hooked, I must have a little frame flex, Does anybody know if they have these trailors engineered or can they just wing it? I would like to know who engineered my 5th wheel frame and fiberglass wall connections? Thanks, Coby.
