RV.Net Open Roads Forum: Fifth-Wheels: Another lesson learned
 > Another lesson learned
mojohelpermonkey
Camano Island, Washington
Posted: 06/23/08 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
I recently learned you can't use cinder blocks under your landing gear. Wish I'd taken a picture, but imagine finding a half crushed block under the leg while your wife and toddler are inside and see how fast you run to get your car jack. Could have been messy, we were lucky.
I also learned that one leg will support the whole front of the 5er, but I doubt any good will come from it. Had the crushed cinder block side jacked up and stuck a jack stand under the other side to try to get the other block out from under it. Raised the landing gear and the leg came right off the block without resting on the jackstand.
2008 Dodge Ram Mega Cab 3500, SRW
2007 Challenger 34BHQ
THE BIGPUNN
west michigan
Posted: 06/23/08 10:53pm Link  |  Quote  |  Print  |  Notify Moderator
i did the same thing, cinder blocked was crushed into a million pieces.
07 Chevy 2500HD D-Max!
05 Forest River Wildcat 31 QBH
goldendagger
moving
Posted: 06/24/08 01:26am Link  |  Quote  |  Print  |  Notify Moderator
wood it's the choice of beaver's.....
who left the light on? is it me or are we leaning downhill. where did the dog run off to
swebber
Brunswick , MD
Posted: 06/24/08 05:06am Link  |  Quote  |  Print  |  Notify Moderator
Does not crush well and would be my choice as well.
Had a friend years ago who jacked up the front of his F250 and supported it with a cinder block while he worked on his brakes. He had his legs under the truck while he worked. He was called inside for a phone call and upon his return he found the truck had crushed the block...counted his blessings that his legs were not under there when it happened.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
Chefd
Arizona
Posted: 06/24/08 07:56am Link  |  Quote  |  Print  |  Notify Moderator
Be sure the holes of the cinder block are up and down. If you set the block on its side it has no strength. By placing the block correctly you will have to use some wood. Forget the block and use wood to start with.
Chefd
Chris
Shelter Bay, Wa
Posted: 06/24/08 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Except on soft ground, the legs are best placed on the ground! If a camp site is that off level get another site. Chris
My Rig
2001.5 2500 STD CAB AUTO SLT 4x4, CTD 4:10's, Bomb'd to Tow
2005 Cardinal 29WBLX.
goin2themountains
Aztec, NM
Posted: 06/24/08 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Ditto, but as other's have stated, unless I'm on soft ground, I don't put any type of block under the landing gear.
Puller: '04 HD2500 4x4 SB,EC Duramax/Allison. Airaid intake, 4in. exhaust turbo back, ORU leveler.
Pullee: '02 Keystone Cougar 276EFS Reese 16k w/ slider.
(map is for current 5er only)
red_neck_camper
Stafford, VA., USA
Posted: 06/24/08 09:59am Link  |  Quote  |  Print  |  Notify Moderator
For the OP -- did you have the cinder block positioned with the holes facing up, sitting on smooth, level ground, with a board laying across the top? It is very rare to have one break, if it is positioned properly. If they did, there would be a million house trailers sittin' on the ground.
I found this out the hard way when I was young and ignorant, trying to block up a house trailer for my cousin. I broke about 6 blocks before I figured out I was stacking them with the holes side-to-side. I turned them over and didn't have any more problems. I thought to myself, "you have a college education and you're dumb as dirt!"
Ken
2007 FORD F-350 4WD SC Longbed, 6.0L Powerstroke, Reese Signature Series 18K hitch.
2007 Keystone Montana Mountaineer 342PHT
mojohelpermonkey
Posted: 06/25/08 12:43am Link  |  Quote  |  Print  |  Notify Moderator
I had the block turned with the holes on the side, did not use wood on top. I'm sure it would probably work the other way with wood, but I'm just not going to use them again. They are too darn heavy, anyway.
