MCR500
Central Calif.
SAS! wrote: Curious Question about the XPS RIBS, These tires are the all steel radials meaning steel belts in the side walls, right? I am guessing that you would destroy these tires if you aired them down to 15-20 PSI in the dunes. Do you guys air them down? I was considering the BFG Commercials for this reason. Am I off base?
I have been running Ribs for 3 years, with multiple trips (30 or so)to Pismo, airing them down to 20 psi.
Have not had any issues at all.
Great tires!! C-Ya!!
04 WW 3705 SLC All the options!!
05 Ford F350 CC DRW 4x4 6.0 w/ power"enhancements"!
Toys:
97 Honda CR500(dads)
05 KTM 525EXC(dads,Cal. Plated! )
05 Honda TRX-250(#1 son)
05 Honda TRX-250(#1 daughter)
98 LT-80(#2 daughter)
00 Big lawn chair(#1 wife)
yardsale1
Orange County, California
Hey USMC,
Are your Carlise tires by any chance "Ultra CRTs?" That is what came on my Raptor, same size you listed. I know they are made by Carlisle and I too, am thinking about replacing them. I was leaning towards the BFG Commercials since they are about half the cost of the RIBS.
2007 Keystone Raptor 299MP
bdougt
Now Louisiana, Eventually Michigan
USMC_2651_E5 wrote:
P.S. My current tire size is ST235/85/R16 and are rated to approx 3900 lbs @ 90psi.
On your setup - what is your spacing from center of hub to center of hub on the trailer?
I want to change also, but have a concern because my spacing is 33". The ribs in 235/85/16 list the diameter as 32", thus only leaving 1" between tires on my setup.
Brian, Donna, and Ted the dog.
2006 Dodge MegaCab 2500 Laramie 4x2 CTD 48RE 3.73 gears
Firestone AirBags - 16K Reese with Slider
2006 River Canyon 34KSTSO - TrailAir Pin - XPS RIBS 245/75/16
USMC_2651_E5
SOCAL
bdougt, Hub to hub measurement is 35 inches. Space between the tires is only 3 1/4 inches.
Yardsale1, Tires are Carlisle Radial Trail ST235/85R16, no "Ultra" anywhere on them.
edited 07/02/08 03:02pm by USMC_2651_E5 *
mapguy
Puget Sound
Dexter Axle states 1" is minimum clearance between tires. If you have 35" axle spacing the LT235/85R16 will fit no problem. IF you have 33" axle spacing probably want to consider the LT245/75R16 size instead. Both of these size tires are good for 3042#. If you need the higher weight rating of a LR G the Goodyear is pretty much your only choice in 16"
Map Guy
JJ&kids
North Tustin, Ca
If your trailer came with G rated tires I don't thing I would move down to E's. I have always gone the other way and moved up to a stronger tire for my own peace of mind.
03 Chevy 2500HD Duramax/Allison Crew Cab Short Bed
08 Attitude T23AK
01 660 Raptor
02 Yamaha 350 Warrior
04 Honda 250EX
04 Suzuki Z400
bdougt
mapguy wrote: Dexter Axle states 1" is minimum clearance between tires. If you have 35" axle spacing the LT235/85R16 will fit no problem. IF you have 33" axle spacing probably want to consider the LT245/75R16 size instead. Both of these size tires are good for 3042#. If you need the higher weight rating of a LR G the Goodyear is pretty much your only choice in 16"
Map Guy
I agree - 35" hub to hub spacing should be ideal.
Not intending to hijack the thread, but a simple question please. My rims are 16 x 6 and Michelin 245/75/16 recommends 6.5 inch wide rims at a minimum. Does anyone see a problem with the 6" rims?
PsnRebel
On My Banshee, In the Dunes !! In SoCal
Why would you air down your trailer tires? I've been dune'n for 20 years and can't remember ever airing down our trailer tires or anyone else in our group.
As far as the XPS' go, we've had ours for a little over a year now. They are awesome, the trailer rides and tows much better. Our trailer is a triple axle WW Cl that is very heavy even empty, and we've had it loaded with absolutely no problems.
They are an excellent tire, pricey, but well worth the dollars.
SAS!
So. Cal.
PsnRebel wrote: SAS! wrote: Curious Question about the XPS RIBS, These tires are the all steel radials meaning steel belts in the side walls, right? I am guessing that you would destroy these tires if you aired them down to 15-20 PSI in the dunes. Do you guys air them down? I was considering the BFG Commercials for this reason. Am I off base?
I guess it depends on how far from the road you want to be? I do not air down unless I'm getting stuck. but I hear it is pretty much required at Pismo? I had all steel radials on a motorhome and the tire shop said if I ever ran a tire flat(Slow leak)to replace it?
2008 Rage'n Falcon 34-05
2004.5 RAM 3500 QC 4X4 SLT SRW CTD 600
2001 Bombardier DS 650
2001 Yamaha Raptor 660
2004 Suzuki Z 250
CORVA........The Action Program........The BlueRibbon Coalition ........aSa
USMC_2651_E5
SOCAL
JJ&kids wrote: If your trailer came with G rated tires I don't thing I would move down to E's. I have always gone the other way and moved up to a stronger tire for my own peace of mind.
I just check the manufacturer sticker and the recommended tires are load range D. The previous owner said he replaced the tires once and must have upgraded to the G rated tires. Since all that is recommended is D rated, I think I'll be good to go with the XPS Rib.
