RV.Net Open Roads Forum: Hybrid Travel Trailers: roo 233 mystery hoses
Open Roads Forum  >  Hybrid Travel Trailers
 > roo 233 mystery hoses
bubbahemi
London Ontario
Posted: 06/24/08 06:23am Link  |  Quote  |  Print  |  Notify Moderator
was crawling under my Roo 233 the other day and saw 2 hoses (1 red 1 blue) that came out thru the floor near the rear of the trailer directly under the outside shower. What are they for?
thanks
Turbo Diesel Dude
Green Mountain, NC
Posted: 06/24/08 06:52am Link  |  Quote  |  Print  |  Notify Moderator
Possibly red-hot water; blue-cold water?
charles weidman
Chuck_S
Broadview Hts, OH, USA
Posted: 06/24/08 06:56am Link  |  Quote  |  Print  |  Notify Moderator
These should be the low point drains. There should be valves up inside the body, you'll have to track them down as they're useful for draining the water system for winterization.
These are ours, but are in a different location than yours. They're T-valves with a short hose sticking out the bottom of the trailer. They're in the flow position.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
djdetrick
PA
Posted: 06/24/08 10:50am Link  |  Quote  |  Print  |  Notify Moderator
Yes as Chuck stated these are the low point drains. In the 233 the valves are located in the cabinet area below the side bunk. Open the last cabinet door toward the rear and look past the partition and under the duct you will see 2 white valves. These are for draining for winterizing why yours are colored I don't know mine are both clear as it shows in chuck's picture and protrude through the floor.
Dave
DW DS DD
2006 Rockwood Roo 233
2007 Ford F150 Supercrew 5.4L Triton
sharker6
Shelbyville, Kentucky
Posted: 06/24/08 10:57am Link  |  Quote  |  Print  |  Notify Moderator
You may have caps on the ends that just screw off like mine do.
2005 Xterra off road 4X4, 2007 26' Aluma-Lite, WD w/ friction sway, Prodigy, Yamaha EF2400, 400w inverter, front carrier w/ rod holders, Dish Network
risingsun
Prescott, AZ
Posted: 06/24/08 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Mine are black valves connected to the red and blue rigid water lines. The hoses that lead to the underbelly from the valves are clear with white braiding for reinforcement. I imagine there were changes sometime around then...
2006 Rockwood Roo 23SS
2001 GMC Yukon SLT
Ugly04
Six Mile, SC
Posted: 06/24/08 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
That is the low point drain. On our 06 233 they were red and blue also.
JD and Belinda
3 boys 3 girls
KZ Frontier 2809
2001 Excursion
1800gerry
Saskatchewn, Canada
Posted: 06/24/08 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
Those are low point drains and ours are red and blued. Rather than the "twist" valves, ours has simple pull (up down) values that are the same as on the holding tank drain.
2008 Shamrock 19
2004 Dodge 1500 Hemi
Wife, Son, Daughter
Dog (Basset Hound)
