RV.Net Open Roads Forum: Direct TV v/s Dish TV Satellite ... Opinions???
 > Direct TV v/s Dish TV Satellite ... Opinions???
jomasw
Paris, Tn.
Posted: 06/24/08 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
I set up my Direct in CG and invariably someone with Dish will come over for help in setting theirs up. Dish must be much more difficult to aim.
Bumpyroad
Virginia
Posted: 06/25/08 04:45am Link  |  Quote  |  Print  |  Notify Moderator
I think your MotoSat Dish will determine which is better. IMHO you should have decided what sat system you wanted, HD or not, etc. before deciding on dish.
bumpy
AeroP
Emery, SD
Posted: 06/25/08 07:01am Link  |  Quote  |  Print  |  Notify Moderator
I have MotoSat and Direct. You can have either, depends on how you set up switches when installing.
AeroP
AeroP
99DSDP
Ames
South Central Florida
Posted: 06/25/08 07:12am Link  |  Quote  |  Print  |  Notify Moderator
We and my son have Direct TV. We have used it at home and in the motorhome for 11+ years and recommend them as a provider. Their satellite is at a higher angle so the chances of signal blockage by trees or other objects is lower. If you get a message to call extension 7__ because your motorhome dish was not pointed at the satellite it can be reauthorized without talking to anyone in less than one minute. No experience with DISH.
Richard and Babs and a Bob Tail Cat
97 Beaver Patriot 40 Kitchen Slide
330 HP Member FMCA, BAC, Good Sam, CAT RV Club
Toad 04 Durango HEMI
SRT
Head of the Lakes, MN
Posted: 06/25/08 07:19am Link  |  Quote  |  Print  |  Notify Moderator
2ndhom wrote:
Just installed a Moto Sat Dish on the roof. My mind is not made up between Direct or Dish. Money wise per month they are about the same. Both provide (for additional money) ABC, CBS, NBC & FOX. Dish doesn't provide as many HD ..... Hmmmmmmmmm!!! Decisions/decisions. Any help in swaying me one way or the other??
Thanks in advance!!
Tom
OH, come see our historic Wood Covered Bridges in Oregon!! You will love all 51 of them!!
We'll be in Portland for a few weeks the end of July. Where are the bridges?
But we've had Dish for about 10 years with very few problems (usually with Indian accents). Just have the basic package. Have the DVR in the house with the orginal receiver in the motor home. Every fall I call them and tell them the motor home is put away for the winter and they "turn off" the motor home receiver. Every spring I call and have them turn it on.
Thanks
SRT
2000 32' HR Vacationer with Banks
1998 Subaru Outback Ltd. 5 spd
Brake Buddy & Blue Ox Aventa II tow bar
FMCA #266040 HRRVC #84109
BaldEagle
Oregon
Never had a problem setting up Dish. After getting the tripod anchored and plum it usually takes me only a minute or two to get a good signal.
Have helped 4 people having problems getting a signal over the years. One had Dish and 3 had DirecTV. All but one were having problems because the setup was not plumb. One (Dish) had a tree in the way of Satellite 119.
2004 Vectra 40AD
2002 MDX Toad/Brake Buddy
Roadmaster Blackhawk
Guardian Rock Shield
sootslayer
Central Pennsylvania
Posted: 06/25/08 09:18am Link  |  Quote  |  Print  |  Notify Moderator
I use Dish and once I learned to use I was ok. Lots of operator error at first. Now I'm ok. I just don't call Dish directly about anything in the coach. It's ok to call with a little problem in the home, but don't waste your time unless you get someone in the US.
good luck,
Hank
SkyCop4U
Fort Worth
Posted: 06/26/08 06:39am Link  |  Quote  |  Print  |  Notify Moderator
KVH R5 System. I am using Dish.
After talking to a tech at both KVH and a tech at my local dealer, here's what I have learned. If your system is set up for Direct TV, and they come that way from the factory, then you need a softwear upgrade to make Dish work better. According to the KNH tech, the latest patch is only 2 weeks old.
I have been told then when I get this installed, my system will work perfectly. I am taking it in for the upgrade (and yes I have to pay for it) on Tuesday. I'll report back.
sherranil
Illinois
Posted: 06/26/08 08:44am Link  |  Quote  |  Print  |  Notify Moderator
We had Dish for 3 years, when I tried to cancel, it took 12 months to cancel, and 3 better business bureau complaints to straighten everything out. They charged my credit card, etc, I wrote letters, tracked my calls & everything. Anyway, we are very happy with Direct TV, can take it with us, or use it in the stick house.
