RV.Net Open Roads Forum: Class A Motorhomes: Found a Wonderful Miracle Product
 > Found a Wonderful Miracle Product
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 06/24/08 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Remington makes Remington Rem-Dri Lube, a teflon lube for guns, but it works great for everything. 4 oz spray $5.99. Unlike WD-40, it lasts a long time, does not wash off, does not attract dirt and gunk, and doesn't run.
REMdry
cm
Dillon, CO USA
Posted: 06/24/08 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
As mentioned you can buy it at most bicycle shops. Also I have found it at some Ace Hardware stores. I have used it for over 15 years.
And WD-40 is a penetrating oil and will attract dirt. Not a good idea to use it as a lubricant. I know a locksmith and he recommends Tri-Flow. He says he loves it when people use WD-40 on locks. Because he makes a lot of money doing service calls on their stuck locks.
WA1RI
FL
Posted: 06/24/08 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, great stuff! Been using it for many years. Bike chain lube, one of the best. And as they say WD40, as good as it is, does not last.
Bill & Jolene / FL
1997 Southwind 35P
2006 Yamaha 1100 Classic &
1970 Norton Commando 750 in state of recuperation (Almost road ready!!!)
6x12 Enclosd trailer
D & M
Laurel, MD
Posted: 06/25/08 06:37am Link  |  Quote  |  Print  |  Notify Moderator
That's becasue WD-40 is basically kerosene. It does a great job of breaking things free but it has no staying power.
You need to folow it up with a good lubricant.
Dave & Mary
Isabel (a cuddly little Boston)
Buddy (The Beast) another Boston
2005 Itasca Suncruiser 35A
2003 Jeep Liberty
If it's listed in the Yellow Pages, the government shouldn't be messing around with it.
Ames
South Central Florida
Posted: 06/25/08 06:53am Link  |  Quote  |  Print  |  Notify Moderator
I have always been advised to use WD40 as a cleaner and it is similar but not as strong as Blaster for cleaning things like our Remco Drive Shaft Disconnect and step pivot points. For lubrication some type of non oily silicone lubricant so it does not attract dirt. We bought some of the Kwikee spray and it seems to work well after the WD40 cleaning. We have also found the silicone lubricant sold at auto parts houses work about the same.
Richard and Babs and a Bob Tail Cat
97 Beaver Patriot 40 Kitchen Slide
330 HP Member FMCA, BAC, Good Sam, CAT RV Club
Toad 04 Durango HEMI
Dakzuki
Carnation, Wa, USA
Posted: 07/04/08 11:16pm Link  |  Quote  |  Print  |  Notify Moderator
http://www.boeshield.com
Brilliant stuff. I use it on locks, door hinges, the bike chains, I smear it on my axes and hatchets, you name it.
I discovered it when trying out different lubes for bike chains. It's my favorite.
95 Chinook Premier
alcolby
yuma az.
Posted: 07/05/08 06:27am Link  |  Quote  |  Print  |  Notify Moderator
If you don't think WD-40 is a lubricant, spray some on you shoe soles before going up on the roof.
{the point being, it IS a lubricant}
Al C
Doug and Cassi Glass wrote:
WD 40 will work for a while but it isn't a lubricant, it's a water displacer, in fact the 40th formula they tried. Hence WD-40.
Craig P.
Posted: 07/05/08 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Doug,
Thanks for the tip. My steps drive me cazy as well and nothing seems to work. I'm gonna hunt down some Tr-Flow this weekend!
2005 Providence 39J
2007 Tacoma PreRunner Double Cab Dingy
2002 EZ-Go Custom Electric Golf Cart
Thousand Trails & Coast to Coast Members
jhilley
Buxton, ND
Posted: 07/05/08 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a can to try on my steps. I have been using the Kwikee spray lube. My steps weren't going in all the way. I tried the Tri-Flow and they work great now. It's not as messy as the Kwilee product either.
KOG
Winterville GA
Posted: 07/05/08 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
You have to be careful with that Tri-Flow. I put some on bedroom door hinges and the door then swung so easily that we had to put a magnetic catch on it to hold it open or it would swing half way closed. It did that for nearly 10 years before it stopped swinging free.
We originally got it for bicycle chains about 30 years ago. Great stuff for chains.
