RV.Net Open Roads Forum: General RVing Issues: sewer hose storage tubes
 > sewer hose storage tubes
C.B.
APPLETON WI USA
Posted: 06/25/08 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
4 X 4" Fence post cover with PVC rain gutter slid inside. Store anything that will fit. This one is 8' long and can be pulled out from either side.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
TORQSHIFT AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE
PRODIGY BRAKE CONTROLLER~C-BETR MIRRORS~ROTOCHOKS
CB Family Fleet
Butch&Barb 03Cardinal~Duane&Holli 05CedarCreek~Kris&Katy 06Cherokee~ Brian&Maia 04Jayco
summutt2002
Over here......no, over there!
Posted: 06/25/08 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
Well done, C.B.....I'm impressed. Now it occurs to me that one could just put a rain gutter in the regular 4" bumper and be done with it.
Great wife, 3.1 dogs and no money..LIFE IS GOOD
'01 Excursion Ltd 7.3L PSD pulling a '06 Prowler 260RLS, Equal-i-zer, Prodigy
LarryJM
NoVa
Posted: 06/25/08 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
havedreamwilltravel wrote:
summutt2002 wrote:
Go to HD or Lowes', or any other similar. You can find round stuff, square stuff, and probably oblong if you want it. You can get it with holes (for draining, tho holes are an invitation to wasps IMHO) or without. Sewer hoses fit in the 4" size, as mentioned above.
But if you want to fit the fittings I believe you need to upgrade to 6".
The 4" square fence post cover will handle the straight sewer fittings and even the CAMCO easy slip sewer fittings. It's tight, but works just fine.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974. TRAILER MODS
LarryJM
NoVa
Posted: 06/25/08 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a pass thru using something like the vinyl downpipes for gutters makes a great storage option.
These are my two pole holders I mounted in my rear pass thru storage compartment. The holders are 10' 2x3 inch downspouts attached with downspout brackets. Now I can keep my toilet wand, center awning support pole, extra expandable pole for washing cleaning the trailer and my awning pull down rod. Now I can get my awning rug out w/o removing a bunch of other stuff and all my rods are in one place.
Larry
Jim102
Cabot, Arkansas
Posted: 09/17/08 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
How do you attach the 4" PVC pipe to the bottom of the unit? I was thinking of using those long zip ties or metal straping. What have you used? I have two lengths of sewer pipe, just in case, each compacted is 5' in length, do you just leave them connected or have openings at both ends of the pipe?
Thanks,
Jim
2007 29' Maverick 292 DS
A 12 yr. old long haired Doxie, "Digger"..
LarryJM
NoVa
Posted: 09/17/08 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Gotagetgoing wrote:
Does anyone know what the internal diameter of the E-Z sewer hose storage tubes that camping world sells is? I was wondering how useful they would be for storing things other than sewer hoses.
For my sewer hose I used one of the 4" vinyl post covers that are much, much cheaper than PVC and you can also get them in the 5" variety.
Larry
Wherever I happen to park
Posted: 09/17/08 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
I used six inch pipe, I think the ones you cite are 5 or 6. 4" should do it but I find the end connectors won't always fit in a 4 inch pipe
