RV.Net Open Roads Forum: Fifth-Wheels: snap, crackle & pop goes the frame
 > snap, crackle & pop goes the frame
Kathryn's Fate
Kansas
Posted: 06/24/08 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
I don't remember hearing any sounds for the three years I owned my old, 2005 5er, but it was much lighter in weight.
My new 5er makes the snap, crack & pop noise when lifted or lowered on the on to the hitch.
Is this normal for a semi heavy 5er?
Thanks,
Fate
2008 Carriage Cameo 32SB2
2007 2500HD 4WD Crew Cab Duramax Allison LBZ
2003 Cobalt 246 8.1 Volvo Penta Duoprop
2000 Suburban 2500 6.0 4.10
John H
Kansas City Mo.
Posted: 06/24/08 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
Fate,
You will have to locate the source. You or someone else is going to have to get their ear close to the sound. Its just to broad of a brush to ask is it normal.
John H
Kathryn's Fate
Kansas
Posted: 06/24/08 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks John, the sound comes from the bedroom floor frame area. I'm going to start paying closer attention to it.
Thanks
Fate
retired logger
WA USA
Posted: 06/24/08 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
I had about the same problem with my MH after about 40K miles. The sound was coming from the duel wheel area. So one day I decided to find the noise problem... I pulled my dual wheels off, then the wheel well covering. Right behind the wheel covering between the upper floor and lower floor was a sheet metal brace, it had a fatigue crack about 5 inches long causing the brace to give off a waffling sound. I drilled out the end of the crack, and reinforced it with a sheet metal brace and walla no more noise. BTW, I pop riveted the brace in place instead of welding, ( I was scared of a fire problem).
Short time young and a long time old !
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/24/08 11:57pm Link  |  Quote  |  Print  |  Notify Moderator
Go onto the toyhauler section of the forum. There was a particular brand of toyhauler using Lippert frames that had cracking problems behind the pin box area and under the floor of the bedroom. One symptom was the cabinets in the bedroom were tweaked and didn't line up right. If your trailer uses a Lippert frame, it could be related.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
lat471
Lebanon, PA
Posted: 06/25/08 05:44am Link  |  Quote  |  Print  |  Notify Moderator
That's pretty standard on the Cameo's. Nothing is breaking it's just the weight shifting. I asked about the same on the Carriage site and that's how I found out how common it is.
07 Cameo LXI F35FD3
R Taj-We-Haul
woodburner
Mentor Ohio
Posted: 06/25/08 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Ours (Everest) does the same....not enough to cause concern but enough to let you know the weight is shifting.
http://www.everest-owners.com/
rusty_poth
Airdrie Alberta
Posted: 06/25/08 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Lippert frame?
Snap crackle and pop?
Tell me it isn't so?
We had our 5er's suspension collapse in Rapid City last year due to their gosh darn gee whillikers awesome welding practices! If you want proof just PM me and I can give you plenty of photographic proof.
Oh and we also had to have some reconstructive surgery done to the frame around the bedroom slide as well when the spot welds that Thor put in busted and started seperating the outside wall.
It kills me that we pay so much for these rolling homes and after a few years they start breaking down after the warranties run out and the manufacturer tells you politley to go for a long swim, and then you find out "oh the manufacturer knowingly employed sub-standard practices during the build process.
Okay, I will hop off my soap-box......carry on...........
* This post was edited 06/25/08 01:52pm by rusty_poth *
Retired 22 years Regular Force (Army/Air Force), 3 years Army Reserves.
2004 Dodge 1 Ton 5.9 Cummins, 2004 Thor Jazz 3100XL 5th Wheel.
rusty_poth
Airdrie Alberta
Posted: 06/25/08 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
dbl post sorry........
mwebber78
New England
Posted: 06/25/08 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Amen brother - they are terrible at QC, all of them - mostly becuase they are assemblies not fabricated parts they use to build a coach. They have little to no control over the components they use..
Michael
2 DD's and my DW
6 Acre's of Maine
2009 Crossroads Cruiser CF31SB
2008 Chevy 2500HD Ext. Cab LT 4X4
Champion lil' yellow Chinese genset, 4000W
Camping Pictures
