Gruffy
monominto mb ca
I was told this was normal too. Then I pulled the covers off and found all the broken welds. Now I rent a site for 12 months of the year.
Yeah Lippert!!!!!
vwsportbug
Ontario, Canada
Can't be a Lippert problem. Carriage make there own frames and they are a well proven design over the years. Ours does some creaking as the weight switches from the pin box on the truck to the front jacks. Has never been a problem. There is an aluminum sub frame boxing in part of the Cameo's bath/bedroom area that is probably responsible for the creaking and cracking noises. The Carri-Lite and Carriage models have a fully welded steel sub-frame in this same area. I wonder if that prevents the creaking noises on those models?
VeeDub
2006 Carriage Cameo LXI F35FD3
2006 Ford F350 Dually
loveshack1
Whitewater, Wi
Our '94 Carri-Lite still does the snap, crackle, pop and creak thing. I used to freak out and then I discovered there's nothing wrong, just the weight settling.
But then...............one day the wife heard it, and now I have her convinced we need to trade it in on a newer Carriage. Maybe the Domani???
If electricity comes from electrons, does morality come from morons?
Mr. executive
Newburgh, New York
Lippert had a recall a few years ago on their frames. The 2000 to 2004 frames had a weld cracking problem in the front pin area that was used by a number of manufactures. I know my frame was recalled and I had to take it back to the dealer and they took the front cover and the pin box off and had to weld some braces into the frame.
Mr. Executive
5th Wheel N.Y.
Dustytuu
Colorado USA
vwsportbug
You are right, Carriage makes their own frames, is a big reason we bought a Carriage.
Ours also pops and crackles too. The weight shifting.
2008 dodge 5500, diesel,Laramie cab, pressure pro tire.
2008 Carri-Lite 36SBQ, 4 slides,dishwasher,washer/dryer,2 fireplaces
D & D
Two Schnauzers, & cat
http://s6.photobucket.com/albums/y250/Dustytuu/
Criminals prefer unarmed victims!
Kathryn's Fate
Kansas
Well, it sounds like those with the same manufacture as my rig make the noise, and is normal. Carriage builds their own frames with a 5 year warranty on Cameo(7 years on the higher end units), unlike the Lippert frames with two years, if I remember correctly.
Fate
2008 Carriage Cameo 32SB2
2007 2500HD 4WD Crew Cab Duramax Allison LBZ
2003 Cobalt 246 8.1 Volvo Penta Duoprop
2000 Suburban 2500 6.0 4.10
luvlabs
Frederick, MD
I'll give you another location you might want to check - your truck's rear suspension. I've noticed the same sound when hooking up when I had my 2500HD and my 3500HD. I don't believe it is the trailer frame, just the rear suspension settling in.
BTW - Carriage makes their own frames.
Carriage Cameo 33CKQ | 08 GMC 3500HD CC LB Duramax Dually | Sam the Cat and the Labs | Best wife going
FisHin2Dmax
Utah
ALL trailers with leaf spring suspensions make some sort of sound as the weight is being shifted from front to rear and side to side. The weight shifting noise ( normal)is less on the morryde rubber suspension systems. Rarely is it the trailer frame that is making the noise, but rather the suspension components in both the trailer and the TV.
2003 GMC HD 2500 CC 4x4 DuraMax/Allison
2008 Sundance 2900MK
