PAUL3500HD
N.W.Ohio
How many people have tried to open the Egress (fire escape) Window prior to an emergency?
Is this common practice?
Personally, I never have and don't know if it would go back in afterwards.
Just asking
2006 3500 Silverado CC D/A Dually 4x4 LT3
Summit White
15K REESE
2005 K-Z Sportsmen 3052px2 Limited
Prodigy
MY PICTURES
More Pic's
3500 DUALLY CLUB MEMBER # 128
beemerphile1
NE Ohio
I suppose different ones work differently. Mine you just slide the window open, slide the screen open, and then dive. I stopped after opening it, I'll save the dive for a real emergency since it will probably hurt.
If your emergency exit utilizes a non-opening window, it will probably require some work to reinstall it. Maybe even require replacement. But, how do you know if it truly will open in an emergency? Do you trust your manufacturer, well, do ya?
Tim
"Okay, I admit it, the only thing I'm really good at is being me."
Support the "No Child Left Inside Act"
2006 Weekend Warrior FK1900
1998 Ford E150 4.6L
1996 BMW R1100GS
2005 Trek Madone 9spd.
1995 Burley tandem
susan-y
North Bend Oregon
mine is back by the bed and has two latches. I open the latches and the whole window, frame and all, swings up. Really simple and easy. I always check my escape routes but like Tim will save the jump for an actual emergency! Sue
2005 Chateau Sport w/slide, 24ft, E-450, V-10
Life looks better through a windshield.
NCHornet1
Mt. Airy, NC.
Mine has a lever and slide out from the bottom, I open it often to get fresh air in at night. But I promise you if there was a emergency I would run through flames to get out the front door before I would ever try to exit through that so called emergency exit!!!
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
festus_
Carol Stream, IL
I open them regularly and train the rugrats in their use regularly. They need to know how to use them on their own.
The one on the lower bunk that hinges out is used at least as much as the front door by my daughter ( When she's not climbing in the rear underneath storage hatch and then out the inside understorage hatch out the front door and around again ).
'05 Wildwood 25EX
'03 Ram 1500 5.7L Hemi SLT QC SB 4x2
rvten
Crossville,TN
Emergency Escape LOL!
Only had 1 RV that had a good escape window. Now most are for small people and those with no physical problems.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008
Class C passed Class A owner
Pontiac G6
There is NO such Thing as a B+
D & M
Laurel, MD
Yes, you need to check them. If it doesn't go back in you have a problem. It's no time find out when that it's jammed with flames licking at your butt.
All of the ones I have seen are hinged but be aware that this may not be so on your vehicle.
Dave & Mary
Isabel (a cuddly little Boston)
Buddy (The Beast) another Boston
2005 Itasca Suncruiser 35A
2003 Jeep Liberty
If it's listed in the Yellow Pages, the government shouldn't be messing around with it.
Vet Man
Ct. & Florida
This is a complaint I have when you purchase a unit from a dealer. They almost never operate the Emergency exit with you to show you how it works. The frist time I tried mine I had someone outside to catch it if it falls. Mine was hinged at the top. Hope this gets people to try there's before it is needed.
2008 Itasca Sunrise 35A
2006 44ft Breckenridge
2008 Honda CRV Toad
2007 ZR1 Colorado Toad
2008 Pontiac Solistice GXP "Brazen Orange"
2008 26ft Car Mate-Car
"We Traveled To Alot Of Different Places While On Vacation, Until The wife Asked Directions"
Wherever I happen to park
I can not answer "how many" but I can tell you I've opened both of mine, and re-closed them.
Some RV's, Like mine, you can open and close 'em
Some you can open and replace them (That is once opened you can not re-latch)
There are advantages to both systems but in my case I've used the window for assorted jobs
Oakman
MO
I tested mine in both my old fifth wheel and my new one. What I really like about my cheapie Wildcat is that it has a large bedroom window that goes all the way to the floor. For escape in a nighttime fire all I have to do is open the window remove the screen (or kick it out), lay on my belly and slide my plump little body out.
2002 Dodge 2500 V10
2008 Wildcat 28RKBS
Honda 2000 gen
TomTom One 3rd edition GPS
