RV.Net Open Roads Forum: Truck Campers: Honda competition
 > Honda competition
s1214
Vt
Posted: 06/25/08 07:41am Link  |  Quote  |  Print  |  Notify Moderator
I just got a new Northern Tool catalog in the mail. They list a 1000 watt Honda wannabe. It's lighter, runs longer, quieter, and less money. Thinking of ordering one today.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200359067_200359067?cm_sp=Customer%20driven-_-Recently%20Viewed-_-Category%20Page
Left_coast*9
Bonney Lake, WA
Posted: 06/25/08 07:47am Link  |  Quote  |  Print  |  Notify Moderator
My strong recommendation is don't do it. Y'konw how it goes, "you get what you pay for"! This is a textbook example....and for about $850-890 shipped to your door for a Honda, it's well worth the extra $$, and that's for the EU2000i!!! Do some searching on here for where to get one for this price.
2006 Dodge CTD, SRW LB 4WD AT, bags, 19.5 Visions and Hankook 265s, Hellwig Rear Swaybar, Ranchos
2007 Eagle Cap 950, EU2000i, dual Trojan 6V T105s, pretty well loaded
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/25/08 08:01am Link  |  Quote  |  Print  |  Notify Moderator
Any generator with a Kohler or Yamaha engine is a good choice as well.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
Keith M
Cle Elum
Posted: 06/25/08 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Ok back in January a lot of guys got the All-Power 2000 watt generator at Pep Boys for %200-$300 which was probably a pretty good bargain. A little noisier and more fuel consumptive than the Honda but you cant argue with the savings. I havent seen the cheap All-Power since then but now I see Northern Tool has the 2000 in stock for $312. The 1000 is no bargain but the 2000 which isnt sold in California because its either high polluting or it very defective would be tempting. Both generators are noisier and more fuel consumptive and I am guessing might only last 1000 hours or so. They are also slightly heavier than the Honda. The cheap generators fill a nich for occaisional boondockers who arent going to disturb neighbors and emergency use around the house. A mail order Honda 1000 for around $635 will actually be cheaper over its life than the cheap chinese generator plus you have parts availabilty and it will be quieter.
This one makes more sense if you go cheap
bedrocker
lompoc ca
Posted: 06/25/08 10:11am Link  |  Quote  |  Print  |  Notify Moderator
I have had one of those
for 2 yr's now and it
works great it is a
honda knock off the motor
looks just like one 300 bucks
it's a killer deal use the $
you save on gas and go camping
Heavy_Hauler
Carlsbad
Posted: 06/25/08 11:26am Link  |  Quote  |  Print  |  Notify Moderator
The All Power uses more fuel and has a square wave inverter. Whereas, the Honda has a true sine wave inverter. Other than that the All Power looks like an inexpensive clone of the Honda.
Go ahead a buy one and let us know how it works!
Honda EU1000i produces a clean sine wave of energy that does not spike and safe for sensitive electronic equipment.
Specifications: EU1000iA2
Engine: Honda 1.8HP (50 cc) Single Cylinder, Overhead Valve, air-cooled
AC output: 120V 1000W. (1.0 kVA) max. (8.3A), 900W (0.9kVA) rated (7.5A)
Rated Frequency: 60 Hz (cycles)
Receptacles: (15A 125V** DUPLEX) "2 household type receptacles"
DC output: 12V,100W (8.3A) For charging 12V batteries
Starting system: Recoil
Fuel tank capacity: 0.6 gallon gasoline
Operational capacity on one tankful: Approx. 8.7* - 4 hrs. @ rated load of 900W
Dimensions (LxWxH): 17.7" x 9.4" x 14.9"
Noise Level: 53* - 59dB @ 7 Meters
Dry weight: 28.6 lbs.
Shipping Weight: 34 lbs.
Oil Type: 10W-30
Fuel Type: 89 Octane unleaded gasoline
Cooling System: Forced Air
Max. Engine Speed: 3,600 RPM
* With Eco-Throttle On
_________________________________________
All Power America Portable Inverter Generator — 1000 Watt, Model# APG3101
• 1000 surge Watts
• 900 running Watts
• 1.8 HP OHV 4-stroke engine
• One 120V AC outlet
• One 12V DC (5A) outlet
• 7.5 Amps @ 120V
• 0.8-gallon fuel tank provides up to 5 hours runtime @ 1/2 load
• Inverter technology delivers consistent current for computers
• Brushless motor for high efficiency and longer life
• Only 54dB noise level
• Built-in carry handle
2004 GMC Sierra 3500 4x4 D/A EC LB DRW
Ride-Rites, RS9000X, TorkLift, Fast Guns, Superhitch
2007 Lance Max 1181
dokkema1
Chicago
Posted: 06/25/08 11:36am Link  |  Quote  |  Print  |  Notify Moderator
$35000 Dodge CTD
$25000 Lance 1181
$900 Honda generator seems like a Bargin to me
JoeChiOhki
Keizer, Oregon
Posted: 06/25/08 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Why the devil does a generator need Mid-grade gasoline? (Referring to the honda above)
CB Channel 17 Space Ghost
'1991.5 Dodge W-250 Power Wagon - Club Cab Long Bed V8 5.9L 4spd H.D Auto 4x4 4.10 Gears
'1987 Pullman Mini Camper
'2004 Bi-Mart 4x8 Cargo Trailer
Boatycall
Tacoma, WA
Posted: 06/25/08 11:48am Link  |  Quote  |  Print  |  Notify Moderator
We had a similar discussion on a knock off genny a while back here.
I'm a huge proponent of doing what you can with what you've got. The genny mentioned in the thread I'm referring to was a 3.5KW for something like $200 if I recall. That was a deal. Can fire a roof air, or anything else you want.
But the one you're talking about isn't much less than a Honda. $439 for a knock off is A LOT. I personally think it's overpriced.
The comparison on the previous thread was a $200 knock off vs. a $1000 Honda. In this case, it's a $439 knock off against a $600 Honda. I really would go for the Honda, if for nothing else, proven reliability.
'01 F350 CC DRW 4x4,4" turbo back exhaust,SCMT,pyro tranny temp& boost gauges,4.10 gears
'03 Arctic Fox 1140,4 Trojan T105s,1.5kw inverter,icemaker
92 YJ 35's,6" lift,ARB lockers,Ford 8.8, 8k winch
Honda 400ex
10k 24' toybox
221, 221, whatever it takes.
LeavLance
Leavenworth, KS.
Posted: 06/25/08 11:50am Link  |  Quote  |  Print  |  Notify Moderator
I run my Honda on regular (87 octane) with no problem. I do not recall my manual saying it required 89 octane. I'll have to look at the manual again.
2002 Chevy Silverado 2500HD, 2005 Lance Lite 915
 > Honda competition
