RV.Net Open Roads Forum: How hard is it to change the gears on an SUV??
Search only in Tow Vehicles
 > How hard is it to change the gears on an SUV??
Canadian Karebear
Saint Albert Alberta
Posted: 06/25/08 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
Im reading so much about gear ratio's and given the poor performance of my vehicle on hills while towing, Im wondering if it's the gears that I need to be concerned about.
How much time and effort (or is it even possible) is it to change the gears to increase towing performance?
Sorry about the dumb question, but I am rather inept when it comes to mechanics of a vehicle.
Thanks.
Mommy , Skyler , Sammy...the wonder dog
TV: 2000 Ford Explorer Sport 2dr 4WD
HTT: 2004 Jayco JayFeather 18ft Hybrid; Prodigy brake control (with Eaz-lift WD hitch)
See you around the campfire!!!!
Nature does nothing uselessly...
bufordt
Pennsylvania
Posted: 06/25/08 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
If you have to ask you probably should not attempt to do it. But a competent mechanic can do it and the cost is usually around $600 - $800 per axle. It can make a great improvement in both your towing ability and economy. A vehicle that is lugging a trailer through the hills is way less that a comparable vehicle that is at higher rpm's but at better torque multiplication.
Road Ruler
Canada
Posted: 06/25/08 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
Getting these vehicles to handle with trailer in tow has been a challenge over the years.
The towing specialist here in the area have worked on many and have come up with a formula that works. The one mod you should check out is this one....
Upgrade the P235x75x15 tires with a 215x75x15 LT (load range C) tire.
The LT tires have a stiffer side wall, fit the Ford rim better and is smaller in Dia so you get a similar effect as changing gears. The whole combination will feel much more stable overall. To verify the info you could check with Can Am RV here in Ontario.
Canadian Karebear
Posted: 06/25/08 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
How many axles does my vehicle have?
Jacdanboy
North East
Posted: 06/25/08 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Ok you are banned from doing it
SUV has 2 differentials - which is what you are worried about in most cases. (oh and the axle term is technically wrong, your vehicle probably has 4 of them)
hemi-kz
Eastern PA
Posted: 06/25/08 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
If lugging on hills is the problem, no need to go to all the expense of changing axle gears, just down-shift the transmission. Higher axle ratios help with getting a load started from a stop. Because there is no gear lower than first. But if you are going up a hill in, say, third gear, then shifting to second will allow the engine to run faster, where it makes more power. It's the total (transmission * axle) gear ratio that matters.
2007 KZ 22 Sportster Hybrid Toy Hauler
2003 Dodge Ram 2500 4x4 Hemi Quad Cab Short Bed
1990 Harley Electra Glide Classic
2005 Harley Sportster 883L
horton333
Newmarket (Ontario)
Posted: 06/25/08 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Your sig says 4WD.....
For such a small trailer a gear change may not be required. I had good results with going to a lower profile tire as is suggested upthread. Even has a side benefit of the kid driving slower, as I never changed the speedometer programming so it reads 'high'.
Caddywhompus
Southeast WI
Posted: 06/25/08 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
In addition to Road Ruler's very good reply, I will add the following;
Is the high cost of having your differentials changed to a steeper final drive really worth the expense? What kind of performance issue are we talking about here, and exactly how much of an annoyance is it for you? Enough to spend $1000-1500 to correct? Is it possible that we are just expecting a little too much from our tow vehicle by asking it to climb every grade at the speed limit without down shifting? I'm just speculating is all.
Lets say you have a tough time climbing a grade in direct drive (3rd gear for you) so the truck wants to drop to 2nd gear. Why not slow down, move over into the truck lane and let it pull the grade in 2nd at a slightly lower speed. Once you remove some of the aerodynamic drag from traveling at the higher speed and allow yourself to drop 10-15mph you may well find you can easily pull the grade with some pedal leftover AND without listening to the motor scream along at 4000rpm needlessly.
Sure it might take a few minutes longer to get to the top, but your aren't flogging the motor for everything it's got. And by running in the lower gear you reduce the input torque required to move the combo so your transmission sees less load as well. You will probably find that on these steeper grades you aren't moving any slower than OTR trucks or older Winnebagoes anyway.
Just food for thought.
'04 Ford Freestar (Primary tow vehicle)
'05 Subaru Forester (Backup tow vehicle)
'65 Bethany popup (best popups ever made!)
Looking for a tow vehicle
Minivan towing
mecreature
Indianapolis, IN
Posted: 06/25/08 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
the tire suggestion is a good one... since at some point you will need tires anyway..
and dont be afraid to slow it down a bit.
eurohazard
Travis AFB, CA
Posted: 06/25/08 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Pretty good solution and cheaper. Odometer and speedometer will be off, but that might be able to compensated for through adjustments/calibration.
2, if that was a serious question.
-2006 Nissan Armada LE 4x4
-2007 Coachmen 19FLB SE
-2007 Regal 1900 w/ 4.3 EFI Volvo
Supercharged wrote:
4-in-a-fiver and my statments make the same amount of since.
