RV.Net Open Roads Forum: Travel Trailers: Fresh Water Tank
 > Fresh Water Tank
mostek
Little Chute, WI
Posted: 06/25/08 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Instead of trying to pour water into the outside fill hole for the fresh water tank, has anyone attempted to add a fill hole on the top of the tank? Maybe something that can screw in and out?
Thanks in advance.
Nick
hemlox
Western Illinois
Posted: 06/25/08 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks in advance.
Nick
You don't "pour" the water in. I use a HOSE.
25 ft. Gulfstream Conquest
Chevrolet Suburban 4x4
Reese Dual Cam WD Hitch
Prodigy Brake Controller
kearlms
Rexburg, ID
Posted: 06/25/08 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
hemlox wrote:
Thanks in advance.
Nick
I second the hose. Makes life much easier
mostek
Little Chute, WI
Posted: 06/25/08 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
I'm talking about putting in more water from jugs and such while camping after the fresh water has run out.
hemlox
Western Illinois
Posted: 06/25/08 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Yes thats what I am talking about, I run a hose to the nearest spiggot and refill the tank.
mostek
Little Chute, WI
Posted: 06/25/08 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
I would like to be able to fill the tank to a piont without having to leave the site that we are on though.
Thanks
Shooter47025
Lawrenceburg,Indiana
Funnel with a long flexible spout works very good.....
'05 Silverado 2500 Z71 6.0
26'Prowler,Reese Dual Cam
Bird Hunter/Brittany's (2)
Quick trip
Cerritos, Ca.
Get yourself a large funnel, stick it in the fill hole and pour the jug water in.
Make sure the opening is about 3/4" or bigger!
Good Luck & Drive Safe!
hemlox
Western Illinois
Posted: 06/25/08 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
I carry 100ft of hose, I can usually reach a spiggot. If that is not possible use the funnel.
mikehart92
Oklahoma
Posted: 06/25/08 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
When I camp during deer season, I would need a half mile hose to get to the nearest spiggot.
How about a hose that slips over the spiggot on the juggs?
I have a plastic 55gal drum that I have installed a valve with a long hose on it. I can strap it down on my tool box, fill from the top bung, then when I get to the camper I just install the hose and open the valve. No more holding a jug while it pours into the tank.
They do make a large bladder than you put on the roof of you tv. Again, drop the hose in the tank and let gravity do the work.
Mike
Boilermakers Local 592
2005 Chevy 2500HD.............6.6 D/A, 4x4, Crew Cab
 > Fresh Water Tank
