tomlove
Delaware
On our last trip we found our shower drain running slow. I checked all of the plumbing Operating and Maintenance manual, but didn't find any information on acceptable drain cleaners for the system
Does anyone have any experience or knowledge of a safe way to clean slow drains in an RV without ill effects on the pipes and grey water tank?
Camper with wet feet,
Tom
mikehart92
Oklahoma
Try putting water in the tub then using a plunger.
I have used Draino but I run my own risks. I wouldn't let it set in the holding tank but the trap is made out of the same stuff your household plumbing is. I waited the 15minutes then ran lots and lots of water through to flush it out.
Mike
Boilermakers Local 592
2005 Chevy 2500HD.............6.6 D/A, 4x4, Crew Cab
dturm
Munster, IN
Check for hair or other debris in the drain fixture in the tub. I have to clean ours pretty frequently. Yes, I'm going bald!!
Doug
Doug & Sandy
Megan (14 yr old Golden)
99 Pace Arrow 37S
2001 Honda CRV
Check out blog.rv.net
BaldyD1
Central Florida area
Remove the screw that holds the strainer/metal plate w/holes plate onto the shower drain connection {probably the reason for slow draining}, clean the metal strainer, and pour a gallon of hot water into the drain. If that does not free-up the drain, use a flexible snake and clean the P trap and again pour a gallon of hot water into the drain. Good luck.
Speedy, Jackie & Dusty {Shih-Tzu/Maltese}
2006 Kountry Star KSDP 3912
2005 Saturn Vue (dinghy)
DutchmenSport
Indiana
A good plumbing store has drain cleaner. It's not actually cleaner. It's emzines that eat everything organic. Perfectly safe on all pipes as the little emzines (bugs) eat the bad stuff, they multiply, eat more, and multiply and eat more until everything is gone and then they get flushed down the drain. High Rise apartments use this as do Cruise Ships. I've got some I use in the house. A tablespoon full down each drain with a cup of warm water and the little critters go live!
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
Ames
South Central Florida
Go to a hardware or other store such as Wal Mart and get a plunger. Get the one that is under $5. They are environmentally friendly and do not harm rubber seals. What you pull out may not be very pretty but expect at least 10 years of use before you have to replace it. We have had to purchase two in 30 years of RV'ing.
Richard and Babs and a Bob Tail Cat
97 Beaver Patriot 40 Kitchen Slide
330 HP Member FMCA, BAC, Good Sam, CAT RV Club
Toad 04 Durango HEMI
Fulltimers
Anywhere, USA
I am assuming you can’t get to the P-trap? I just remove my traps once in a while and using a baby bottle brush I clean them and the pipes as far as the brush will reach.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2001 Saturn SC2 (Mr. Toad
Photos
acker1
fulltimer
Go HERE and then go to a hdwe store and get one. You won't regret it. It works great!
DICK
37'--'98 Endeavor
toad--'05 Crewcab GMC
Viet Vet '65, Ia Drang Valley survivor (We Were Soldiers)
Elks
www.4ezdaz.com Same site, different URL
Economical Handyman
S. California
acker1 wrote: Go HERE and then go to a hdwe store and get one. You won't regret it. It works great!
DICK
As posted, works great, cheap and easy to store.
DeWayne & Judy
04 3810 Dutch Star
ISL 370
Frank's autoformer
01 Sahara Jeep-toad
F 374382
It is hard to kiss the lips at night, that has chewed your butt all day long!
tahiti16
Camarillo, CA
I bought one of these because my wife's cat likes to lay in the sink which constantly backs up. Fortunately on our coaches the pipes aren't very long, especially the shower, this is soft enough and cheap enough to try before harsh chemicals. By the way since we dump in somone elses sewer, i.e. campgrounds or other dumpstaions stick with a product that says safe for septic tanks if you use chemicals.
sorry forgot the link the first time
small drain snake
Ray, Cheryl, Cory & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 6 speed auto 2 slides 7.5 KW genset
