RV.Net Open Roads Forum: Tech Issues: Check valve for shurflow pump?
 > Check valve for shurflow pump?
goingnorth
Petersburg, MI
Posted: 06/26/08 06:12am Link  |  Quote  |  Print  |  Notify Moderator
My shurflow 2088 pump bleeds back into the fresh water tank in about 2 hrs so the pump cycles. I proved this by turning the pump on to build presure, turned pump off and closed the suction line to tank and opened the suction line for winterizing and let it sit, it filled the hose up. My pump cycles on at 20psi and off at 40psi. Over night it doesn't go bellow 15psi. My Jayco is an 04 and it has cycled like this since new. I took the pump apart and it looks clean.
Can I install a check valve in the suction line or will this cause problems when priming up? Also the check would have to be horizontal because of limeted space.
When the pump cycles my 2 year old keeps saying "Whats that", it wakes him up from naps and at night if I forget to turn it off. I am in process of insulating the hoses for noise and might install a 1 gal. surge tank too, if I can fit it.
Thanks
08 F350 FX4 CC SB 6.4L
(sold)99.5 F250 sc lb 3.73ls 4x4 100k
28' Jayco talon zx toy hauler 10,000# w/o toy's, tongue wt 1600# Titan Tow Beast wd hitch Dual Cam
22' Renagade 3place snowmobile trailer 2000# w/o toy,s
dbbls
Missouri
Posted: 06/26/08 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Yes, you can install a check valve in the intake line. It may lay in any position. There are also rebuild kits for the pump.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
goingnorth
Petersburg, MI
Posted: 06/26/08 08:03am Link  |  Quote  |  Print  |  Notify Moderator
CW has the rebuild kits for $45 but this happened since new, so do they all bleed down over night and cycle, or was mine bad from the beginning?
wmiles
SLC, Utah
Posted: 06/26/08 08:30am Link  |  Quote  |  Print  |  Notify Moderator
If I remember correctly, Sureflow pumps have a two year warranty. When my pump did this I called Sureflow and had a new pump a few days later. I installed the pump and problem fixed.
Wyatt
2007 Prowler 250RLS
1996 F250 PSD
jferre9570
Southeastern MA, USA
Posted: 06/26/08 11:28am Link  |  Quote  |  Print  |  Notify Moderator
The three little rubber diaphragms serve as the pumping mechanism and are supposed to prevent back flow. If yours leaks backwards, you either have worn diaphragms or foreign material between the diaphragm and seat, and that foreign material can be darned small and still cause this problem. IMO, for the cost of a diaphragm kit(Shurflo calls it a "valve assembly") vs the price and installation of a check valve, I would replace the valve assembly.
John & Diane
1996 Beaver Monterey 3403
2002 Ford Windstar toad
sharker6
Shelbyville, Kentucky
Posted: 06/26/08 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Here's an easier way. Turn the pump off when your not using water.
2005 Xterra off road 4X4, 2007 26' Aluma-Lite, WD w/ friction sway, Prodigy, Yamaha EF2400, 400w inverter, front carrier w/ rod holders, Dish Network
