RV.Net Open Roads Forum: Tow Vehicles: HELP!! Re-setting GMC "Driver Information Center"
Search only in Tow Vehicles
 > HELP!! Re-setting GMC "Driver Information Center"
DOTLDaddy
Camp Canine, Union, MO. U.S.A.
Posted: 06/26/08 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Arrrggghhhh!!!
I have changed my oil recently on my "new to me" 2003 Sierra. Now, however, the "change engine oil" display comes up when I start the engine. According to the manual, I can re-set this by using the buttons on my steering wheel. The problem is, I ain't got no buttons on my steering wheel!
I have tried pushing in, holding in, etc., the stalk sticking out of the instrument panel next to the speedometer, but to no avail.
How the heck do I re-set this thing!!?? With my old truck, it involved stepping down on the accelerator several times within five second, or something like that, I don't recall exactly. Is this what I need to do again??? It does not say anything about that in the manual.
Walter & Garland - Camp Canine caretakers
Gen. Gretchen - 4 y.o. GSD - Special Forces/Seal/DOTL Cloudbusters
Gen. Missy - GSD/Aussie - Special Forces/DOTL Rainbow Division
2003 GMC Sierra 2500HD
2008 Puma 25RBSS TT
mikehart92
Oklahoma
Posted: 06/26/08 09:49am Link  |  Quote  |  Print  |  Notify Moderator
From my manual...
To reset the eingine oile life system, do the following...
1. turn the ignition key to run with the eingine off.
2. fully press and release the accelerator pedal three times within five seconds.
if the oil life reset message flashes for 10 seconds, the system is resetting.
3. turn the key to lock.
Mike
* This post was edited 06/26/08 10:00am by mikehart92 *
2005 Chevy 2500HD.............6.6 D/A, 4x4, Crew Cab
crickeydog
Marietta, Ga.
Posted: 06/26/08 09:52am Link  |  Quote  |  Print  |  Notify Moderator
Check your manual again. I have the steering wheel controls but my manual also gives instructions for trucks like yours. If you can't find the instructions, PM me and I'll check my manual for you.
Happy camping!!! See ya'll down the road!!!
AIR FORCE RETIRED "EITHER LEAD,FOLLLOW,OR GET OUT OF MY WAY"!
2006 GMC 3500 SLT CC DRW 4X4 D/A LBZ,PREDATOR & FS2500 OIL FILTER
2004 HR PRESIDENTIAL 30 SCD 5'ER.
CHEROKEE & CHEYENNE, MINI DOXIE'S
LOADED LIKE A FREIGHT TRAIN, FLYIN LIKE A JET PLANE!!
DOTLDaddy
Posted: 06/26/08 10:05am Link  |  Quote  |  Print  |  Notify Moderator
crickeydog wrote:
Check your manual again. I have the steering wheel controls but my manual also gives instructions for trucks like yours.....
That is the maddening part! I have studied the manual several times and it says nothing about re-setting the DIC if you do not have the steering wheel buttons. I can scroll through each of the available sections of the DIC by pushing the stalk, but I can't change anything except the tripmeter.
wtravlr1
Palm Harbor, Flordia, and Geneva-on-the-lake, Ohio
Its in the manual, but hard to find. Also when you resent, it does not go back to 100% oil. Each time mine goes down a bit. tried the cleaners etc. While it does not reset to 100% it also takes longer to go down. Dealers have not had an explanation, except that the sensor get "dirty"
2007 Forest River Sierra 31fkd (37') dual slides
chevy suburban 2003 2500-8.1 L.4.10's
prodogy/reese dual cam
rollgard springs
Fulltiming it since 2004.
My Homepage and Rv pics press here
DOTLDaddy
Posted: 06/26/08 10:08am Link  |  Quote  |  Print  |  Notify Moderator
wtravlr1 wrote:
Its in the manual, but hard to find....
I think that might be the understatement of the year!
If you know what it says, please let me know.
coolcamp
St. Louis
Posted: 06/26/08 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
There isn't an oil life "sensor"...the system monitors things like throttle posistion, engine temp, speed, RPM's, shift points and makes calculations on when oil should be changed...I really hope your GM dealer didn't tell you that the oil life sensor gets "dirty".
Back to the question at hand...you will need to depress the accelarator pedal with the key in the on posistion multiple times to reset the monitor.
mecreature
Indianapolis, IN
Posted: 06/26/08 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
mikehart92 wrote:
From my manual...
Mike
This is how you do it.
kaydeejay
SE Michigan, USA
Posted: 06/26/08 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Better than my dealer telling me to ignore the monitor and be back in 3000 miles for my next change! Embarrassed faces when I asked if following the monitor will void my warranty! Then I ripped the sticker off the windshield they had put in there with a "3000 miles or 3 months" date on it.
GRRRR!
Keith J, Retired from GM Engineering
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA.
1999 Sunnybrook 27RKFS Fiver
Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors.
ugeesta
Northeast Ohio
Posted: 06/26/08 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
mikehart92 wrote:
From my manual...
Mike
I just changed my oil last week and the above instructions worked like a charm.
2002 GMC Seirra 2500HD 8.1
2007 Honda Rancher 420
2002 Honda Rancher
1 wife & 3 cats
2003 25' KZ Sportsman Sportster...Yamaha EF2800i
Forget San Francisco, I Left My Heart In Colorado
