RV.Net Open Roads Forum: Folding Trailers: Tire Pressure
 > Tire Pressure
hawk_fan
Medford, OR
Posted: 06/26/08 11:05am Link  |  Quote  |  Print  |  Notify Moderator
What would you guys recommend the cold tire pressure should be at. The tires on the PUP are ST205/75D14. The Max is listed at 50lb. It's currently 45lbs.
'08 Fleetwood Niagara
'07 Chevy Silverado 2500HD CC
Our Mods and Pics
campingrandma
South Carolina
Posted: 06/26/08 11:24am Link  |  Quote  |  Print  |  Notify Moderator
50 lbs cold. Don't run them underinflated, you are just asking for a blow-out!
mike4947
N. Syracuse, NY
Posted: 06/26/08 11:27am Link  |  Quote  |  Print  |  Notify Moderator
Unlike "P" and "LT" grade tires, "ST" (special trailer) tires are only designed to run at the maximum pressure listed on the tire side wall.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
hawk_fan
Medford, OR
Posted: 06/26/08 11:34am Link  |  Quote  |  Print  |  Notify Moderator
Thank you grandma and Mike. 50 it is then!
rrupert
NW PA (Oil Heritage Region)
Posted: 06/26/08 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Did you check the tire inflation sticker on the side of the trailer. It usually gives a TP for the tires at maximum trailer load.
Joyce and Rich
2005 HiLo 1705T
2007 Fleetwood Sun Valley Popup (Our 5th PUP)
2007 Toyota Tacoma Crewcab
Amatuer Radio K3EXU
hawk_fan
Medford, OR
Posted: 06/26/08 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
No, I took the info right off the tires.
smkettner
Posted: 06/26/08 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
Trailers have the smallest possible tires to carry the rated load.
Unless you have installed larger tires, run the max listed on the sidewall.
mike4947
N. Syracuse, NY
Posted: 06/26/08 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
With ST tires even if you've replaced the tires with higher rated tires you still use the maximum inflation pressure listed on the tire side wall.
Again ST (special trailer) tires are DESIGNED to ONLY run at the maximum inflation pressure.
Also do not try and out guess the tire manufacturers by thinking that pressures increase when driving so you should run a few pounds less. They have been making tires for over 100 years now and they know about the pressure increase and have designed for it.
AND set your pressures before driving. That's why we recommend buying one of the inexpensive 12 volt compressors. They may take a long time raising the tires to the correct pressure, but that's better than driving to somewhere and then guessing what to put in because they have increased from driving.
smkettner
Posted: 06/26/08 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Maxxis inflation chart
mike4947
N. Syracuse, NY
Posted: 06/26/08 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Every ST tire builder has those charts, But get one to say run them at the lower pressure for a lower load and you'll be the first.
We went through this several years ago when I made the mistake of if a little bit larger is good, then huge would be great.
I replaced tires with ones apx 70% higher in weight carrying capacity and the tires would come off the ground at every expansion strip. We forget how much of the suspension is actually in the tires; and to make a long story short the 6 tire manufacturers I contacted ALL said to only run them at the maximum pressure as that's what they were designed for. No one could give me an answer as to why they all had the inflation charts showing reduced pressures for reduced loads, other than to say well we have them for our other types of tires.
 > Tire Pressure
