RV.Net Open Roads Forum: Technology Corner: Digital Television identification
 > Digital Television identification
bdpreece
Woodburn Oregon
Posted: 06/26/08 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2004 National Tropi Cal which has a RCA flat screen tv in the front and a 19 RCA non flat screen in the bedroom. Both of these TV's were probably made in 2003. Without removing the TV's to get the model numbers how can I tell if they are digital or if I will need a converter box? The manuals seem to be of no help at all.
Brian & Loretta
Chance (Golden Retriever)
2004 National Tropi-Cal T396
2005 Suzuki XL-7 toad
We moved!! No more nasty neighbors, no more rotten parking. I am saving this picture just to remind myself how bad it was.
sch911
Rochester Hills, MI
Posted: 06/26/08 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Both have analog tuners only most likely. In the menu system where you select to scan and program channels there would be an additional choice for digital. If you Cable and Air only then you need the box....
2003 Damon Challenger 348 Class A - Triton V10
Posted by Macintosh
campercajun
Central Texas Hill Country
Posted: 06/26/08 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
If the owner's manual doesn't tell you how to tune in digital channels, chances are your TV has no digital tuner. You can look on the specifications page of the manual (usually located in the back of the manual) to see what type of tuner the TV has. If you have only an NTSC tuner, you can't tune in digital channels without an external digital (ATSC) tuner plugged into one of the input jacks. If you have an NTSC (analog) and ATSC (digital) tuner, you can tune in both. You might read your manual and find out how to make your TV do a channel search. If it has a digital tuner, it should find digital channels and add them into the programming memory so that you can tune to them with the up/down channel button on the remote or on the tv. Our Toshiba Regza LCD HD TV we bought for our RV found and programmed both all the analog and all the digital channels available in our area the first time I commanded it to do a channel search. There is a menu we can use to command the TV to skip either analog or digital channels, depending on our preference, but for the present time, I haven't tried to use it. I simply let the TV load all available channels for now.
2003 GMC Sierra Crew HD; 6.0L; Prodigy
2006 Thor Tundra 30RL-DSL; Reese Strait-Line & Dual-cam HP
2001 Honda Elite Scooter
Jim & Gayle Bryant
Murphy's Law: "Anything that CAN happen, WILL."
Bryant's Law: "31 years of RVing? Probably already HAS."
Enjoying the Lagniappe
Destin,FL,US
Posted: 06/26/08 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
If you can tune to channel 55.2 or 55-2, 34.5, 34-5, etc then it has a digital tuner.
bdpreece
Woodburn Oregon
Posted: 06/26/08 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
Nope!! Darn the bad luck.
