sandjunkie
Yorba Linda, Ca
I have an LE 3305 and I can't locate the front speaker wires by the cargo hold. They must be up in the wall somewhere. Any ideas on how to fish these out? I followed the external wires from the radio area to the light in the bathroom and it must go down the wall from there to somewhere near the sticker but I can't find it. Thanks guys
05 F350 CC LB SRW 4X4 Lariat 6.0 Torqshift
06 Weekend Warrior LE3305 Billet Edition
alarmin
california
There is a tool called a Tone Generator (it may have other names as well) you can use it to trace / locate the wires you need. I'm sure the tool is NOT cheap for a 1 time use, so if you know someone who works with low voltage wiring (phone guy, alarm guy, etc) you can borrow theirs. I believe Home Depot carries this tool.
dwrat
Phx, AZ
I have the exact same trailer and my wire come out right next the the front landing gear..
Aaron H
Mesa, AZ
I have the same trailer (make/year), and I was only able to find the front speaker wire; I never found the prewire towards the back of the trailer. Good luck, keep us posted.
AH
2003 Honda CR80R
2004 Suzuki Z400 Limited Ed.
2005 Yamaha YFZ450
2006 Yamaha Raptor 700LE
2006 LE3305 Weekend Warrior
2008 GMC 3500DRW
2008 Harley Heritage
golfman
Sanger CA
OK, on one side of your trailer there is a large black plastic ABS pipe. After a long weekend, take the cap off the large pipe and look up inside as far as you can see. Then grab the large black pull handle and pull as hard as you can. You'll be surprised at all the "stuff" your gonna see.
2006 Vortex 277 Toyhauler, 2000 Chevy Crew Cab 454 One Ton long bed 2wheel drive.
2004 Polaris predator
2005 YFZ450 Special Edition
2006 Yamaha 700
2005 Yamaha Rhino SidexSide 4wd with locking diff.
2000 Honda XR200
2000 Honda XR250
MCrankyPants
Dayton OH USA
golfman wrote: OK, on one side of your trailer there is a large black plastic ABS pipe. After a long weekend, take the cap off the large pipe and look up inside as far as you can see. Then grab the large black pull handle and pull as hard as you can. You'll be surprised at all the "stuff" your gonna see.
Now...that just ain't right! lol
Seriously, on our old WW, the wires were hangingjust inside the outside wall, if you lay on your back and look up in between the outside wall and frame, you should see them.
Hope this helps!
edited 06/30/08 09:15pm by MCrankyPants *
2007 Teton Experience Sunrise pulled by 2003 Dodge 3500 Cummins HO 6-spd. 4x4
'61 VW Double-Cab
golfman
Sanger CA
MCrankyPants wrote: golfman wrote: OK, on one side of your trailer there is a large black plastic ABS pipe. After a long weekend, take the cap off the large pipe and look up inside as far as you can see. Then grab the large black pull handle and pull as hard as you can. You'll be surprised at all the "stuff" your gonna see.
I'm just glad I was there to help
Golfman
jeepgeek
Rancho Cucamonga, CA
Sandjunkie
I am one of those phone/wiring guys. Give me a call and I could stop by on my way home from Costa Mesa with my toner. That way you can verify which wire is which behind the radio while were at it.
909-767-0069 Cell
George
05 Chevy 3500 LT Crew Cab Dually, 06 WW SLC3905,
03 Jeep Wrangler, 4.5" Rubicon Express coils 1" body lift, 35" tires, 9000 lb winch, rock jock dana 60/detroit/4.88 rear, Dana 60/ Detroit /4.88 front
07 Raptor 700R, 07 Kymco 90 (X3)
sandjunkie
Yorba Linda, Ca
Thanks for the help guys. Well sort of
George, I'll take you up on that. I am it South Carlsbad now until Sunday but I will give you a ring next week. Thanks for the helpful offer!!!
