RV.Net Open Roads Forum: Hybrid Travel Trailers: Digital TV
mrradio
Jamestown, ND
Posted: 06/27/08 07:02am Link  |  Quote  |  Print  |  Notify Moderator
This may have been covered in the past, but when all the TV stations are broadcasting digital hi-def over the air,
what modifications will be needed to receive a tv pictures in an RV?
Just a different TV? A box between the coax out and the TV?
How about units like my Jayco that came with a flat panel TV standard?
Thank you
thecaptain
Belleville,Mi.48111 USA
Posted: 06/27/08 07:08am Link  |  Quote  |  Print  |  Notify Moderator
If your TV has a digital tuner you are all set . If not you will need a box . Cneck the sepc in the book that came with the TV it should tell you if its digital . If not get a coupon on line like they have been talkihg about.
Ken/Ellen(RET)
2000 F250 Superduty
7.3psd/Banksbrake/Smartlock/Trans command/3.73gear/Edge EZ module
2002/29ft-Terry 5er:
Take life one day at a time.
sch911
Rochester Hills, MI
Posted: 06/27/08 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Since it sounds like your current TV's don't have digital tuners built in, you will need to install a digital converter box for each TV you have in your RV. There are many available at just about any electronics retailer. You can also get up to two $40 discount coupons for the boxes here: Converter Box Program
2003 Damon Challenger 348 Class A - Triton V10
Posted by Macintosh
ccattie
Smyrna, DE
Posted: 06/27/08 08:42am Link  |  Quote  |  Print  |  Notify Moderator
You want to check and see if your tv has an ATSC receiver built in. Analog tv in the North America is NTSC. As long as your TV has ATSC, you'll be ok. *Most* of the newer LCD TV's have it built in.
-c
2006 Jeep Liberty CRD - sold
2005 Ford Expedition NBX
2002 Keystone Cabana
3 Dogs 1 DW
Buckeye Chuck
Grand Rapids, Mi
Posted: 06/27/08 08:52am Link  |  Quote  |  Print  |  Notify Moderator
If your TV was manufactured after March 1 2007 it should have the ATSC tuner built in. If that is the case that's all you need to receive the digital signal. If you want HDTV your TV must be an HDTV capable of either 720p or 1080i resolution. There is also 1080p resolution but no stations are broadcasting in 1080p yet and probably won't be for some time to come.
-BC-
2005 Antigua 215 SSO
Former....Ranger XLT Super Cab 4X4, 4.0 V6, 4.10 gears
Now......2006 Ford F150 Super Cab FX4, 5.4V8, 3.73 gears.
ram96
Port Matilda, PA
Posted: 06/29/08 11:18am Link  |  Quote  |  Print  |  Notify Moderator
I had a tv repairman tell me that even if you have a box to convert the signal, if you are not within 30 miles of the broadcast origination, you won't get a picture.
He said that you would be better off looking for a dish.
03 ram 1500
R-Vision C191
jkment
Nebraska
Posted: 06/29/08 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
I finally hooked up a digital converter to my 2006 ROO Concertone TV/DVD/Stereo receiver. I hooked it to an antenna out plug then ran wires to the RCA input jacks on the receiver. Unfortunately... the audio went in through the Concertone, but the video did not.(Big Surprise!!) I was able to hook the video plug straight to the LCD monitor.
I am using a Radio Shack converter. I am very impressed with the picture quality and the range. I am able to pull in more stations than just with the analog antenna.
It works well with my power antenna.
I think you will be happy with it.
Jeff
2006 Rockwood Roo 23B
2004 Chevy Silverado ( formally 1999 Blazer)
2 pretty girls, one hot wife, and a mutt!
Car Guy
Just outside Madison, WI - America's Dairyland
Posted: 06/29/08 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
Sort of an odd question and slightly off topic...
Do the converter boxes generate a lot of heat? I am picking one up later this week and have a tight spot to put it in. Also, does it have to be in a horizontal position to operate or can you set it on end?
Thanks for any insight!
Car Guy & Family
2007 Ford Explorer XLT V-8 w/Magnaflow
06 Jayco 232 Hybrid
Rallys attended-5; Statz Family Kamps-7 Kalvin Kamps-6
In Wisconsin we're more than
Beer, Brats, Cows, Cheese and Polka Music
Come see for yourself!
Camping in Wisconsin.com
aepowell
Sherman,tx.
Posted: 06/29/08 10:40pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Rca and it will set eather way
Anthony & Margie Powell
Sherman,Tx.
2001 Jayco Kiwi 23B
2000 Chevy Silvarado
Old
1995 Rockwood Freedom 2280
2000 Chevy Blazer
2009Roo23SS
AL
Posted: 07/01/08 12:37am Link  |  Quote  |  Print  |  Notify Moderator
We've got a digital flat screen LCD in the Roo but also went ahead and got a digital converter box since it's only $9 with the coupon, it's so tiny it doesn't take much room. It's just in the Roo because someday somewhere we will be camped around someone that will need it. We have always done things like that (extra drinking water hose sections, plenty of fuses, hockeypucks (we wouldn't give away a dogbone and when we were in the popup we had 4 complete extra latch sets in our tool/fix bag as well. By the time we said goodbye to it
a week ago, we were down to 1 but we have 3 new friends out there in the world for giving them the latches) So if you see us at camp and you need something besides cash of course (snicker) ask. we may have it. just a bad habit I guess. spare this , spare that.
our roo pictures @ http://community.webshots.com/user/Our2009RockwoodRoo23SS
Married 50-somethings
^2009 Rockwood Roo23SS ^^2008Trailblazer w/Equalizer 1000/10000&TekonshaProdigy90185^^2008 Toyota Tacoma^^2008 SouthBay 925CRTT-EXPi/oPontoonboat^^2007TrackerNitro750Bassboat
