ct camper
ct
Dicor hubcap style wheel covers are a sloppy fit and one came off once and I got it back, but came off again in an area that was not safe to retrieve. I know they were on properly as I check tire pressure before hitting the road after every campsite and due to the loosening of the caps I made sure they were snug.
I called dicor and they claim that they have never heard of a hubcap coming off. I find that hard to believe. The lady I talked to on the phone promised a return call which never came.
Has anyone secured the tension fit type hubcaps with a mechanical fastener etc.. so they would not come off again and how did you do it?
Thanks
Dennyf
Oneida New York 13421
Had same problem and was solved by installing Chrome wheel liners, I lost 3 covers on mine. The liners are not to expensive and they install very simple and look much better. In my case Jayco payed for them.Denny
ADIRONDACK CAMPER
Roger Bebacksoon.
Clinton Twp., MI.
I have lost both rear caps one in Maine the other in Fla. I got some crome hobby paint and solved that problem
donee
Simi Valley, Ca. 93063
FWIW, IV got Wheel Master covers on mine and havent had any trouble with them.
05 Monaco Esquire 29PBD
05 Silver Dodge Cummins w/3.73 gears 4 spd auto.
Tonijim
Newton MA USA
I managed to knock one of my rear dually wheel covers out of round by striking a stone wall on a narrow, windy road. Subsequently, the cover would periodically come loose, held on only by the valve extenders - a hairy situation on the road. I tried to rubber hammer the cover back into round with only limited success. My wife suggested a solution which has worked for two years - criss-crossed bungee chords connecting the underside wheel to the cover. Not too attractive but functional, and a whole lot less expensive than trying to replace the cover.
Jim
aeejbe
Van Nuys, CA
Found a "reasonable" solution ... ...
But you gotta pm me.
TakingTerns
NE Pa
I found it impossible to check tire pressures with the wheel covers on. Correct tire pressure is a safety issue - chrome wheel covers are not. My wheel covers are now sitting inside a cardboard carton in the stick house. They will remain there at least until we need new tires, at which time we'll consider having the ritzy extended metal valve stems put on.
2008 Four Winds 5000 28A (Chevy)
2006 Subaru dinghy
Taking our home-built sea kayaks - Arctic Terns - for a little exercise
ct camper
ct
@ aeejbe -- pm sent
I called wheelmaster and they were, along with me, of the opinion that duallys should have liners in them.
I called Winnebago and they sent me two new ones, but just replacement dicor hubcap type.
I am toying with something along the line of a piece of strap steel and bolting it to the hub bolts and then using a locking nut on a bolt to attach the hub in the middle. It should'nt look too bad.
